Need some help with my crx my motor won't turn off!!!
Old Mar 14, 2007 | 04:59 PM
import2nrmaui's Avatar
Default Need some help with my crx my motor won't turn off!!!
Hey I need some help I got a question about my 1991 Honda crx with a b16a the car runs fine just the motor won't turn off I can take out the key and all the dash lights and radio go off but the motor still runs. Only way I can turn it off is put it in first gear, hold the brake and pop the clutch. I can actually take the key out and drive the car, only need the key to start it. Over here the honda dealer told me it was the starter so I got a new one but samething still won't turn off. Any info will be greatly appreciated Thank You
Old Mar 14, 2007 | 05:02 PM
J_CRX's Avatar
Default Re: Need some help with my crx my motor won't turn off!!! (import2nrmaui)
It's not your starter. You need a new ignition.
Old Mar 14, 2007 | 05:09 PM
think its the ignition switch is there any way to test it cause I no like buy a new one and it still won't turn off.
Old Mar 14, 2007 | 05:25 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (import2nrmaui)
You can also turn it off by squeezing the vacuum line that goes to the fuel pressure regulator. That way you won't wear out your clutch anymore.
I have no real idea on how to fix your problem though.
Old Mar 14, 2007 | 05:38 PM
J_CRX's Avatar
Default Re: Need some help with my crx my motor won't turn off!!! (J_CRX)
Doesn't hurt to take your ignition out and take a look at it. If you know what you are doing, then you can test continuity between each terminals in each different switch position (you'll find a 4 pins and 5 pins connector from the dash fuse box, to make sure you can trace those wires and it should link you back to your ignition switch). But like you said, if you can pull your keys out, then no dout that your ignition lock cylinder is likely broken (replace it).
Old Mar 14, 2007 | 08:14 PM
gp70hs's Avatar
It definitly is not the starter. It most likely is not your ignition switch. Most likely when you, or whomever did the engine swap, ended up crossing a non-switched hot lead back into the switched hot lead. I would backtrack and find out what wire or wires got wired incorrectly. If the dealer told you it was the starter, you got someone who did not know what they were doing!
Old Mar 14, 2007 | 10:04 PM
.Manny.'s Avatar
Touching My Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import2nrmaui &raquo;</TD></TR><TR><TD CLASS="quote">Hey I need some help I got a question about my 1991 Honda crx with a b16a the car runs fine just the motor won't turn off I can take out the key and all the dash lights and radio go off but the motor still runs. Only way I can turn it off is put it in first gear, hold the brake and pop the clutch. I can actually take the key out and drive the car, only need the key to start it. Over here the honda dealer told me it was the starter so I got a new one but samething still won't turn off. Any info will be greatly appreciated Thank You</TD></TR></TABLE>
did you backhand the dumbass that told you it was the starter?
Old Mar 15, 2007 | 06:53 AM
HT Chaplain's Avatar
Loved
Default Re: Need some help with my crx my motor won't turn off!!! (.Manny.)
how could it be the starter???????
Old Mar 15, 2007 | 07:37 AM
crx18c1's Avatar
Default Re: Need some help with my crx my motor won't turn off!!! (HT Chaplain)
Tech's at honda dealer ships are funny...the starter? LOL....
My car was idleing at 2 rpms A homeless guy with no teeth told me...."It's Your TPS"
Changed it and it fixed the idle issue guess what? I went back and gave him $20.
Damn honda techs at dealerships
Old Mar 15, 2007 | 07:49 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: Need some help with my crx my motor won't turn off!!! (crx18c1)
Fuel pump cut-off switch. Good theft deter. and would save your clutch... interesting the fuel pump is still running after key removal but all other stuff cuts out...
Old Mar 15, 2007 | 07:52 AM
spastik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Tech's at honda dealer ships are funny...the starter? LOL....
Damn honda techs at dealerships</TD></TR></TABLE>
LOL! that is awesome. i would do the same and hand the guy 20 bucks
Old Mar 15, 2007 | 08:57 PM
Default Re: Need some help with my crx my motor won't turn off!!! (gp70hs)
I dont think its my wiring cause the car got the swap over 6 years ago never had igintion problems before this. So do you guys think I should buy a new igintion switch. My question is wouldn't the switch still be good if all the dash light and radio go off.
Old Mar 16, 2007 | 05:26 PM
has this ever happened to anybody else???
Old Mar 16, 2007 | 05:28 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import2nrmaui &raquo;</TD></TR><TR><TD CLASS="quote">has this ever happened to anybody else???</TD></TR></TABLE>only on a 1986 diesel mercedes
Old Mar 19, 2007 | 07:40 PM
bump!!!
89CRXSi_24
Jan 21, 2012 10:03 PM
efhondaracer27
Jan 21, 2010 10:32 AM
skata89
Jan 14, 2006 10:08 AM
