Passing Emissions Testing
Old May 23, 2002 | 08:26 AM
NawTeeCRX's Avatar
Default Passing Emissions Testing
Yes I used the search function, and only found about 3 or 4 threads related to emissions, but nothing helpful.
Okay, I failed my emissions test horribly(in Illinois). CO and CO2 levels were fine. It's the hydrocarbons(unburnt fuel) that got me. Seems I'm running way too rich. I'm running the ZC ecu on a d16y8 motor(from a '99 civic EX), so that definitely explains it. I thought that turning down the fuel on my V-AFC would do the trick, but I was wrong.
I'm going to borrow an HF ecu from a friend to use for the next emissions test. He tells me that the car will run about 30 minutes before the CEL goes on because he's tried it before and it seems to be 30 minutes each time. Good thing is that the emissions facility is only blocks away from the house, but hopefully the lines won't be long. Otherwise I might just plug in the ECU while waiting in line.
My question is: Will using the HF ecu lean it out enough? Or is the catalytic convertor more likely the culprit?
I'm probably going to try the HF ecu in the next few days, then if it fails i'll try changing my cat. If the HF works, then I probably won't bother changing the cat since I only drive it once a week.
Thanks for the input!
Old May 23, 2002 | 08:56 AM
hybridcrx's Avatar
Default Re: Passing Emissions Testing (NawTeeCRX)
Yeah, my car runs way rich too, and I need to go get an emissions test here in stl very soon. I would also like to hear any suggestions people have. I advanced my timing a tad, and that helped a little, but I still get back fire pretty often.
Maybe one of my fuel injectors is sticking.....hmmm. What are some good feul injectors to get?
Old May 23, 2002 | 12:16 PM
NawTeeCRX's Avatar
Default Re: Passing Emissions Testing (hybridcrx)
ttt
Old May 23, 2002 | 01:25 PM
4potnick's Avatar
oh how i love the good ol' boys in florida. no emissions.
Old May 23, 2002 | 01:26 PM
HumanResource's Avatar
Not sure if these would work for ZC, but for B16's you can use extended reach plugs (NGK ZFR4F-11 )that burn hotter than O.E. plugs. These with and adjustable FPR leaned to the lowest (20-25 psi) should get you through the door no problem.
Old May 23, 2002 | 07:34 PM
Sgt_Ox's Avatar
try using an adjustable fuel pressure regulator, it worked for my b16 to pass cali smog............
Old May 23, 2002 | 07:36 PM
OldSchoolCrxSiR's Avatar
Default Re: Passing Emissions Testing (MrDoHc2)
yeah get a adj. fuel pressure regulator! i need to get one to pass smog!
Old May 25, 2002 | 06:53 AM
NawTeeCRX's Avatar
Default Re: Passing Emissions Testing (HondaHb916)
Man, I failed again! I tried using the Si ECU and turning the fuel down, but almost same result. Strange. I think I'm going to register my car as a show/race car so that it gets a waiver. I only drive it to shows... and between that, once a week on the weekend. I'm going to use up the last allowed test, though to kinda see what's wrong.
Old May 25, 2002 | 12:16 PM
CRXtc 90's Avatar
before you do go to walmart they sell an emissions pass stuff it says they'll pay you if you use it and still fail, try it
crxisok
Sep 2, 2006 10:04 PM
1990-hf
15
Feb 19, 2005 08:38 PM
srebik
Jun 5, 2004 10:11 AM
FourthGenHatch
Apr 19, 2004 05:55 PM
1990hondaHF
13
Jul 12, 2002 07:19 AM
