one side higher than other???
Old Mar 14, 2007 | 02:13 PM
Slowass2dr's Avatar
Default one side higher than other???
so i bough my car like a week ago and ive been doin all this work in the interior it a 1988 wagon. i have noticed that wen u look at the car from the back the left side sit higher than the right. i went under the car and i sae that the right side has a tokico shock in white and the other side had a light blue shock not sure if it was tokico. what can i do to to make the left side as low as the right.....btw it has coilovers all around and the back ones are equaly adjusted
Old Mar 14, 2007 | 02:50 PM
ALLMOTOR CRX's Avatar
does it have adjustable coilovers? if it does just drop the left side a few lines? if i doesnt then they probalbly burned or cut the springs wrong.. one side higer than the other.. so if it has burned or cut coilver just cut the left side more or get it burned more..
Old Mar 14, 2007 | 02:55 PM
Slowass2dr's Avatar
Default Re: (ALLMOTOR CRX)
no thas no the problem at all, they have coilover on they are both dropped all the way stil the left side sits higher than the right, i think is umthing with shocks
Old Mar 14, 2007 | 02:59 PM
i dont think its possible to be a shock even if you had it blown it would still seat probalby.. i would jack up the car and see if the springs is not missplaced inproperly.. it might just be seating on something and thats what makes look so high up.. i would check it out.. might be a misplaced..
Old Mar 14, 2007 | 03:10 PM
Crx Jimmy's Avatar
Default Re: (Slowass2dr)
maybe the guy was a fat *** so he jacked up the driver side so when he got in it was even.
Now thats slammed!
Old Mar 14, 2007 | 03:11 PM
Under Con. CrX's Avatar
thats how my crx looked when i put my lowering springs on but it was just not siting in write so my left side was higher up you check the spring's make sure they are all siting write thats the best i can do
Old Mar 14, 2007 | 03:12 PM
now thats is a fatass.. bastard
Old Mar 14, 2007 | 03:34 PM
Slowass2dr's Avatar
i was thinking it was the shocks cus one of them is a tokico shock color white and the other was in light blue not sure what brand it was, couldnt see it too good
Old Mar 14, 2007 | 04:15 PM
slowcrxsib16's Avatar
i cant believe my girlfriend is posing on subies.... *****
unknownally
Jun 20, 2010 08:31 AM
mouseghb
Suspension & Brakes
Aug 2, 2005 12:49 PM
JTCdudeman
May 7, 2003 08:18 PM
photonjedi808
12
Mar 10, 2003 08:29 PM
OuNcE
Oct 22, 2002 12:00 PM
