Whats the little grey/black connecter for in a 1996 Honda civic DX im so lost! connecting wiring bac
Old Mar 14, 2007 | 02:09 PM
spaceman00's Avatar
Default Whats the little grey/black connecter for in a 1996 Honda civic DX im so lost! connecting wiring bac
I recently had to remove the dash out of the car and remove all the wiring and unplug eveyrthing...
Now im putting it all together and i cant seem to find where this connecter goes...
Its a little Grey connecter on the drivers side with 8 pins on top and 8 on the bottom. Everything is plugged in i have no clue where it goes...could it be the thing you plug into a computer when you check what your check engine means? Its not from the dash either...so maybe it was always unplugged...
What could be the problem.
I have a 1996 Honda Civic DX 2 Dr Coupe.
Old Mar 14, 2007 | 02:11 PM
Slurp56's Avatar
Default Re: Whats the little grey/black connecter for in a 1996 Honda civic DX im so lost! connecting wiring
Can you take a picture of it? The OBD2 service connector is a female connector in a trapezoidal shape.
Old Mar 14, 2007 | 02:14 PM
spaceman00's Avatar
yup will do.
Old Mar 14, 2007 | 02:16 PM
spaceman00's Avatar
Here it is
http://img463.imageshack.us/img463/565/wirehy9.jpg
Thanks for any help ! Its much appreciated.
Old Mar 14, 2007 | 02:19 PM
Slurp56's Avatar
Yeah, thats the OBD2 service connector. I believe it normally mounts on a little bracket up above (and slightly behind) the hood release lever.
Old Mar 14, 2007 | 02:21 PM
Slurp56's Avatar
actually, in your picture, you can see a square hole in that rusty bracket. It goes in there. The pins sit vertical (aimed at your floor board)
shallam
Apr 15, 2012 01:57 PM
djSALIX
Apr 9, 2006 08:21 AM
EF_p1n0y_b0y
Jan 16, 2004 05:41 PM
