what kind of paint should i use to paint motor?
Old Mar 14, 2007 | 12:29 PM
torqueless's Avatar
Default what kind of paint should i use to paint motor?
i want to paint everything black. Head, block, tranny,intake mani..
should i just use that high temp spray paint? should i primer the parts first??
and will it stay, or will it chip like crazy?
Old Mar 14, 2007 | 12:30 PM
Eran's Avatar
HT White Ops
You need to either get it ceramic coated, or use a 1200+ degree paint, like VHT Flameproof or Plastikote Hi-Temp.
Old Mar 14, 2007 | 01:07 PM
BlueIntegraBoy's Avatar
Default Re: what kind of paint should i use to paint motor? (torqueless)
Wouldn't the black paint help retain the heat instead of dissapating it?
Old Mar 14, 2007 | 07:17 PM
Defymeit1's Avatar
anything hi-temp will work unless your trying to paint your header or something then go powercoating
Old Mar 14, 2007 | 07:31 PM
torqueless's Avatar
Default Re: what kind of paint should i use to paint motor? (Defymeit1)
so no need for primer?? do you think it will chip easily?
ferio252
Paint and Body
Mar 2, 2008 06:41 PM
rewerbcrx
Paint and Body
Feb 23, 2008 12:11 PM
jaydem7
Paint and Body
Sep 11, 2007 10:52 AM
Rising sun #1
May 6, 2003 11:49 AM
