Need help opening my hood
Old Mar 14, 2007 | 11:58 AM
sirhavok's Avatar
Default Need help opening my hood
lol like the title says.
so i hav e a 89 civic hb si.
So i cant get it open! its always giving me a problem. but not it just wont open..
i can reache the chord from outside. but cant get it to open. any advice?
Old Mar 14, 2007 | 12:01 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Need help opening my hood (sirhavok)
You may have to pull up on the hood while somebody else releases the latch from inside. After you get it open again you should adjust the latch position so that it closes smoothly. Either that or the spring is getting worn out or is misadjusted.
Old Mar 14, 2007 | 12:15 PM
sirhavok's Avatar
uuuhh the wire is not connected to anything.
its not connected to the latch anymore.. lol
expletive.. how the expletive do i open my hood with no cable to pull the LATCH/!!!!JESUS!!!
Old Mar 14, 2007 | 12:17 PM
90goldhatch's Avatar
Default Re: Need help opening my hood (wiZCo)
or try having someone pull on the latch while you bang on the hood ..thats how mine is lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhavok &raquo;</TD></TR><TR><TD CLASS="quote">uuuhh the wire is not connected to anything.
expletive.. how the expletive do i open my hood with no cable to pull the LATCH/!!!!JESUS!!!</TD></TR></TABLE>
edit: oh cant help you there ...good luck
Old Mar 14, 2007 | 12:19 PM
Slurp56's Avatar
Default Re: (sirhavok)
I'd start by jacking the front of the car up and pulling the front bumper cover away from the car at the bottom. Then reach your hand up there and tug on that there latch. Might have to fish with a coat hanger or something.
Old Mar 14, 2007 | 12:20 PM
ef_zcvtec's Avatar
Default Re: Need help opening my hood (xXLevoNXx)
same thing happpened to me.. just reach in there and find a 1cm square tab with a whole drilled thru it..pull that to the passenger sideof the car..
Old Mar 14, 2007 | 12:21 PM
sirhavok's Avatar
expletive lol! im fucked..yea i cant see **** man. i think i need two people.. anyone in the ontario area wanna come and help?!
Old Mar 14, 2007 | 12:35 PM
sirhavok's Avatar
damn if i knew what to push or what to pull i could get the hood open. but since i ahve on idea what unlatchs it.. im lost. anyone have a diagram?
Old Mar 14, 2007 | 01:12 PM
sirhavok's Avatar
ok this is what im seeing!
this is me laying on the floor looking up and my latch with no cable attached
Old Mar 14, 2007 | 01:16 PM
Slurp56's Avatar
In the bottom right corner of the latch you can see a fork. That holds the outter sheath of the cable. The inner cable would then continue straight to what looks like that square tab. Move that tab towards the fork.
Old Mar 14, 2007 | 01:26 PM
sirhavok's Avatar
Default Re: Need help opening my hood (Slurp56)
do something like this?! im lost man.. where does the actuall cable ball go onto?
Old Mar 14, 2007 | 01:28 PM
sirhavok's Avatar
maybe in one of these square holes? i tried putting it in there. but cant get it to hook on anything
Old Mar 14, 2007 | 01:32 PM
wiZCo's Avatar
Stouts 'n' Scotch
The cable goes the other way around. All you should have to do is move the latch on the left hand side of your picture to the right until the hood pops.
Old Mar 14, 2007 | 01:41 PM
higgunscrx's Avatar
pull the thing this way
Old Mar 14, 2007 | 01:42 PM
sirhavok's Avatar
im so lost
sirhavok's Avatar
Default Re: (higgunscrx)
it doesnt movE lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by higgunscrx &raquo;</TD></TR><TR><TD CLASS="quote">pull the thing this way
Old Mar 14, 2007 | 01:43 PM
import2nr88's Avatar
Move part "A" towards part "B" to open hood.
Then connect the cable stop to part "B" and the ball end of the Cable to part "A" and you should be golden. I would recommend popping hood and then removing latch and re ataching cable and reinstalling latch mechanisum.
wiZCo's Avatar
Stouts 'n' Scotch
You have it backwards! Route the cable in from the other way, the ball hooks into the latch on the left. Or you could just open it by pushing the latch in the direction higgunscrx showed you.
Old Mar 14, 2007 | 01:46 PM
sirhavok's Avatar
let me see if that works brb
Old Mar 14, 2007 | 01:57 PM
sirhavok's Avatar
Wo0t!
ok one more problem the little ball doesnt fit into PART A
Old Mar 14, 2007 | 01:59 PM
wiZCo's Avatar
Stouts 'n' Scotch
It'll fit, it's going to take some jimmying though. Take the latch off and try to feed the ball in that way then re-attach it.
Old Mar 14, 2007 | 02:06 PM
Slurp56's Avatar
haha damn man, maybe you should just take this to the dealer.
I've never known anyone to have faught so much with a hood latch.
The ball has to slide into the retainer, similar to how your throttle cable attaches to the throttle body. Is the retainer broken? If it is, then you need a new hood latch. Look the latch over pretty good before posting more pictures. Make sure that it looks right. In other words, <U>inspect</U> it.
Old Mar 14, 2007 | 02:16 PM
sirhavok's Avatar
the little ball is like 2 times bigger than the hole... lol how is it going to fit?
Old Mar 14, 2007 | 02:24 PM
Slurp56's Avatar
The hole should be slotted, no? Slide the cable through the slot, and the ball catches on the back side of the hole.
Old Mar 14, 2007 | 02:26 PM
sirhavok's Avatar
lol yea i had to take it off.. Everything is good ::thumbsup: thank u all!
