Dished pistons?
Old Mar 14, 2007 | 11:58 AM
Aquafina's Avatar
Default Dished pistons?
Say you have a worked head with a chamber that allows around 12.5:1 static with a 0cc flat top piston. If you want to run around 11.5:1, you can only use a dished piston (I don't know how much troph reliefs affect the CC). Would you run a full round dish, or something like an ovaled dish so you can have a bigger quench area?
Old Mar 14, 2007 | 04:11 PM
NJIN BUILDR's Avatar
Default Re: Dished pistons? (Aquafina)
In the bike engines we build we use a dish that mirrors the combustion chamber.I have heard claims that a hemispherical dish will make more power than a flat floored dish.
Old Mar 14, 2007 | 04:17 PM
Rocket's Avatar
Default Re: Dished pistons? (NJIN BUILDR)
Use a spherical dish.
Cosworth now uses it. Back in da day MAX_CFM sucessfully made spherical dished pistons to run lower compression (and it picked up a couple) on Cup motors. CP Pistons has this too, e.g. SC7017 has a spherical dish.
Modified by Don Lackey at 5:50 PM 3/15/2007
Old Mar 14, 2007 | 05:03 PM
DonF's Avatar
Default Re: Dished pistons? (Don Lackey)
I would match the chamber also. Not exactly an oval, but close, depending on the head.
devious_yeti
May 2, 2016 07:30 PM
Ryan#1
Oct 2, 2008 06:27 PM
melovesboost
Feb 5, 2007 12:10 PM
projectef
Jul 24, 2006 03:44 PM
blazin
Jul 11, 2003 06:11 AM
