IACV!!!!
Okay,
I finally found some iac's for my car. Got them at the junk yard. Well here is the situation:
My motor, B16a SirII. The iacv's that I found were from a del sol with the d16z6 motor and one from a eg dx hatch, the d15??? Well anyways... i put on the del sol one and it worked fine for about 3 days. The check engine light comes on, but the idle is perfect. So I change it. The d15 works fine too... for about 2 days. Now the check engine light comes on and it has to idle down at the stops. I was told that i could use any of these iacv's. Is that true??? Or do I HAVE to get one of a b16????
Peace
Peace
if it bolts to your manifold it will work fine
are you should the fast idle thermo switch isnt the problem?
you need to use the two holes in your TB to diagnose whether your IACV is working properly
buster023
Jun 14, 2012 03:29 PM
