JDM Cluster and USDM VSS
My whole interior is JDM besides front seats and cluster i was thinking about jsut finishing it up and getting a jdm cluster thing is. If i get the cluster since its going to be running on a USDM VSS(Vehcile Speed Senor) will the kilometers on the cluster actually be kilometers or will it be mph. Im not very good on this if a JDM VSS reads different the USDM VSS.
Thanks
Thanks
you could.. get audm or ukdm cluster. arm/leg but will be in mph.. also, depending on year of your itr. you might have to swap all 4 gauges into your current cluster. there are several version on integra and circuitry might be different and certain things won't function.. once difference for example.. immobilizer key won't be present and in a different location.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">you could.. get audm or ukdm cluster. arm/leg but will be in mph.. also, depending on year of your itr. you might have to swap all 4 gauges into your current cluster. there are several version on integra and circuitry might be different and certain things won't function.. once difference for example.. immobilizer key won't be present and in a different location. </TD></TR></TABLE>
Nope, still KPH
The VSS doesn't read MPH or KPH. It's the resistance in the circuitry.
Nope, still KPH
i got one jdm dc2 cluster, if u want do let me know, i plan to let it go cheap. or u need any jdm parts do let me know. My place here have plenty.
Again i would be km. If you have a 98+ dc2r make sure you get a jdm cluster that is 98+ because 96 and 97 clusters will work but your fuel and temp gauges will not work in a 98+ car and vice versa.
its going in my 2000 PY. if i wanted to do things the easy way i jsut get a speed limiter which fools the kph guage to read mph instead of kph. ie if your doing 80kph you really doing 80mph but i rather learn kph. How much you guys selling 98+ spec cluster for
i only have 96 spec, but all wiring still can be done to fit the 98+ , u just offer me a price
or i dont mind let it go for around $35 but u need to pay for postage since it travel quite a distance, est $60 for normal air parcel to the states.
Weak!EG
May 7, 2007 09:07 PM
