91 CRX DX is spudders when accellerator is pressed
Old Mar 14, 2007 | 09:58 AM
ajcigarx's Avatar
Default 91 CRX DX is spudders when accellerator is pressed
The car had been sitting for about one week and when I start the car it sounds okay. But, when I press the accellerator it spudders and does not have power. When it is moving and when I accellerate it spudders and jerks a little. Could it be the spark plus? I have a oil leak and may need gaskets/seals? Please help...
Old Mar 14, 2007 | 07:32 PM
gp70hs's Avatar
Default Re: 91 CRX DX is spudders when accellerator is pressed (ajcigarx)
I doubt it is the spark plugs. That sounds to me like your fuel filter is probably plugged up.
It is located under the car, on the drivers side, in front of the fill tube. My guess would be that it's just plugged up over time and sitting for a week let whatever junk was in the fuel tank settle out, and then get sucked up and into the fuel filter. If you replace it, it will probably run fine.
Old Mar 14, 2007 | 10:04 PM
ajcigarx's Avatar
Default Re: 91 CRX DX is spudders when accellerator is pressed (gp70hs)
Thanks gp70hs, I appreciate the response. I called my mechanic and he told me that it could be the ignition wires. Guess what, I replaced the ignition wires and my CRX is back!!!!!!!!! I thought it would cost me a fortune. This is a great sight thanks.
havok907CRX
12
Jun 29, 2011 01:23 PM
itsjms
Jul 26, 2008 07:06 PM
IMOTEPHT
Mar 21, 2005 03:35 PM
EFPROJECT
11
Jul 4, 2003 01:42 PM
indy_parrothead
May 5, 2003 11:15 AM
