Clicking sound when first accelerating, not while turning.
Recently when I first accelerate my vehicle the car is making a single loud click when it accelerates. It noise is also present when I first accelerate in reverse (not a grind however). The noise does not happen when I am turning. But the sound defiantly sounds like it is coming from a transmission/drive shaft area.
Anyone ever had this experience, or know what it could be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">definitely the inner joint.</TD></TR></TABLE>
Thanks!
But can you be more specific, as to what the problem might be? Do the intermediate shafts need to be replaced over time becaue or wear, or is mine just possibly not properly installed?
Thanks!
you can replace jut the cv joint. Simply it became worn and loose inside. you can give it a try and put fresh grease in there and test if the clicking dissapeared.
no 5.
no 5.
skater5067
23
Apr 4, 2023 09:19 AM
gurlracer_camille
11
Dec 15, 2006 05:23 PM
