Minimum thickness for stock flywheel? Need to shave today
Old Mar 14, 2007 | 08:24 AM
BudMan's Avatar
Default Minimum thickness for stock flywheel? Need to shave today
Sorry guys - I'm stuck without my helms at the moment & need to have my old stock flywheel shave as much as possible.
Can anyone tell me the thickness min/max for turning the flywheel?
Thanks in advance.
Old Mar 14, 2007 | 02:49 PM
OG undercover's Avatar
Default Re: Minimum thickness for stock flywheel? Need to shave today (BudMan)
Standard (new): 0.05mm (0.002 in) max.
Service limit: 0.15mm (0.006in)
But the book does not say if it's for the R or other...
Old Mar 14, 2007 | 03:11 PM
D's Avatar
D
Default Re: Minimum thickness for stock flywheel? Need to shave today (OG undercover)
to make that info worthwhile... that is spec for runout i believe.... unless your flywheel is two thou thick . Off the top of my head, i don't believe helms has a min thickness spec for the friction surface of the flywheel, or min thickness for the . IIRC they give a min thickness for the clutch friction surface only.
If you're shaving to reduce weight... typically, the machine shop will only go so far anyway... most of them don't like taking alot of the cast stock pieces.
D
Old Mar 14, 2007 | 03:38 PM
Default Re: Minimum thickness for stock flywheel? Need to shave today (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">to make that info worthwhile... </TD></TR></TABLE>
Yes I slacked...
To make up for it:
Old Mar 14, 2007 | 05:24 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">Sorry guys - I'm stuck without my helms at the moment & need to have my old stock flywheel shave as much as possible.</TD></TR></TABLE>
You're only allowed to remove as much material as needed to balance
Unless there's another page besides the one Rob posted, you're SOL. Go get a Fidanza 8 lb flywheel and run Honda-Challenge!
Old Mar 15, 2007 | 03:30 AM
BudMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OG undercover &raquo;</TD></TR><TR><TD CLASS="quote">
Yes I slacked...
To make up for it:
Beautiful. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Unless there's another page besides the one Rob posted, you're SOL. Go get a Fidanza 8 lb flywheel and run Honda-Challenge!</TD></TR></TABLE>
Yea - SCCA rules suck. I have to remove my 7.5 Clutch Masters flywheel to put on this heavy sucky thing. Gotta remove my adjustable timing gears too - having them moved to "0-0" won't do the trick 'technically'.
I may even have to remove the new fastline shifter too. I really have to remember to check the rule book before I buy anything now
Old Mar 15, 2007 | 04:20 AM
Larkin W.'s Avatar
Going through the same thing to make my R D-stock legal. I will miss my 7.5lb Fidanza . Not too excited about putting back on the stock Flywheel
trecool44
May 20, 2007 07:15 AM
whitehf
Feb 4, 2006 05:20 AM
delslo93
Feb 22, 2005 05:43 PM
c1civic
Jan 1, 2004 07:51 PM
B_CRUZ!
Jan 18, 2002 06:43 PM
