Rear 02 sensor removal? (wire disapears into body panel??)
99 civic EX- the rear 02 sensor (the one directly into the catalyst converter) It appears the wire from the 02 goes directly into the body of the car into a rubber grommet, where the hell does this thing disconnect at and how do i trace it?
The front 02 was a breeze, but the rear 02 wire seems to be routed quite strangely, never seen an 02 wire routed like that....any pointers or tips?? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 »</TD></TR><TR><TD CLASS="quote">Pull the rubber grommet out..There is a plug up inside there just like on the 1st o2 sensor.</TD></TR></TABLE>
Did not know that thanks, will this cause me to throw a cell? right now i have it wrapped in aluminun foil to prevent the check engine light. the sensor is not scwreder in because the wires are to short to reach the bunge on my test pipe
randyqnt
Oct 16, 2008 08:08 AM
