bad ringlands?? how to check..
Old Mar 14, 2007 | 08:12 AM
Weak!EG's Avatar
Default bad ringlands?? how to check..
i was told my ringlands may be the cause of my power loss.. how do i check the condition of my ringlands?? any obvious signs that they are bad.
Old Mar 14, 2007 | 08:52 AM
eg:R's Avatar
take out pistons
Old Mar 14, 2007 | 08:59 AM
unknown0001's Avatar
Default Re: bad ringlands?? how to check.. (boostedsingle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsingle &raquo;</TD></TR><TR><TD CLASS="quote">i was told my ringlands may be the cause of my power loss.. how do i check the condition of my ringlands?? any obvious signs that they are bad.</TD></TR></TABLE>
Once you remove the pistons from the cylinder walls, it's not advisable to put them back in.
-inspect the cylinder walls, notice a crosshatch?
-if you have the engine out of the car, take the block to the machine shop and overbore your cylinderwalls by .5mm
-if you decide to overbore, purchase overbored pistons and piston rings 75.5mm
-have your machine shop overbore the cylinder walls and then re-assemble the pistons and engine
-might as well inspect your bearings when your engine is appart and if anything have them replaced
it will help any oil burning issues and seal up the compression great
seldon
11
Sep 17, 2008 04:42 PM
DRGnzo
Mar 18, 2008 11:29 PM
BoBo Racing
Aug 30, 2006 09:36 AM
laughinxxx
Nov 29, 2003 11:18 AM
ZERO COOL
Mar 1, 2003 09:23 AM
