1900lbs (w/ driver) crx +160whp = possible 12's?
I know most people hate bench racing; but, I can get my hands on a gutted 88' hf and was wondering if a 1900lb (w/ driver)crx had the potential to run 12s providing good driver and traction (slicks and motor mounts)
gearing? motor? I'm assuming the z6-T. Feasible, but it will be close. Maybe if the 60 ft is under 1.8, that should make it close. Only one way to find out.... the right way! Run that ****!
If it was 160whp and 99wtq i doubt it. If it was 160whp and 120wtq i can see that happening. Gearing is a factor. Torque curve and powerband is a factor. Driver ability is another factor. I say take your car to the track and find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx »</TD></TR><TR><TD CLASS="quote">I think I'am going to try it. It will be my allmotor d16z6 should have about 160whp and ~125wtq. It will probably be summer time though before it is ready</TD></TR></TABLE>
good luck
good luck
thanks for the support. There are a couple guys on d-series.org that are making 150-160whp+ with simular setups.
most of my inspiration comes from doing something different.
link to my build on d-series.org
http://www.d-series.org/forums...63405
i think you will need one hell of a 60' time.. i could see mid 13's possible low 13's if youre a badass driver..
i seen a 88-91 hb with a lsvtec with 180 whp running 12.8-9 on slicks here in fl. he has a b16 tranny and lsd not sure of the weight of the car though. it was completely gutted and cage.. i assume it would be close to 1900..
there is my .02..... goodluck
set your suspension up well....
shawn
shawn
95DXCIVIC
Mar 21, 2004 07:40 PM
