What axle seal with ls int. shaft in SIR trans
Old Mar 13, 2007 | 08:53 PM
spoonfedcrx's Avatar
Default What axle seal with ls int. shaft in SIR trans
I have an 88hf with b16 SIR swap. I currently have an sir int. shaft and d/s axle. I need to replace the axle and located a integra int. shaft. Do I need to swap out the axle seal too. I couldn't find anything and I'm not trying to run into any problems. Thanks in advance.
Old Mar 13, 2007 | 09:39 PM
.Manny.'s Avatar
Touching My Member
Default Re: What axle seal with ls int. shaft in SIR trans (spoonfedcrx)
if you need to replace the seals...i used 90 integra seals
ThaEfSwap
Mar 24, 2014 04:09 PM
traxxasx
Oct 3, 2008 07:59 PM
migs
Jul 22, 2004 02:41 PM
riot
Apr 14, 2002 07:04 PM
