Checking my bore: Is this gauge ok?
Old Mar 13, 2007 | 07:24 PM
Tippyman's Avatar
Default Checking my bore: Is this gauge ok?
http://www.harborfreight.com/c...94873
Are the anvil sizes ok for checking the bore of my A6? (75mm)
Is it a good buy all in all? I've never bought engine machining tools before...
Old Mar 14, 2007 | 04:25 AM
mmuller's Avatar
Mad Scientist
Default Re: Checking my bore: Is this gauge ok? (Tippyman)
well, for general checking i would say go for it untill you think your ready to step up to the real bore gauges which go for about 3/500 used ( sunen, miyi, old central, brown &)
the problem with those is getting them to repeat redings, would not trust it more than to the .0005
Old Mar 14, 2007 | 08:34 AM
Rocket's Avatar
Default Re: Checking my bore: Is this gauge ok? (mmuller)
Just get a $20 0-6" dial caliper. It will be good enough for you to check if your bore is std, 0.010, 0.020 over etc. Leave the precise bore measuring to your machinist otherwise you will just be creating headaches for yourself.
Old Mar 14, 2007 | 06:55 PM
Tippyman's Avatar
Default Re: Checking my bore: Is this gauge ok? (Don Lackey)
All I want to do is check the bore too see if it is the same all the way down.
Old Mar 15, 2007 | 09:56 AM
Rocket's Avatar
Okay, if you want to check for bore taper then you will need to use a bore guage. You can get a 2-6" bore 0.0005" resolution guage for about $60 - 80.
Old Mar 15, 2007 | 05:08 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">Okay, if you want to check for bore taper then you will need to use a bore guage. You can get a 2-6" bore 0.0005" resolution guage for about $60 - 80.</TD></TR></TABLE>
Sorry for being a noob, but I thought this was one.
Do you have any links that I could look at to see what your talking about?
Old Mar 15, 2007 | 05:30 PM
Rosko's Avatar
I just bought a guage similiar to that, different brand (Fowler) but looks identical. It has .00005" resolution (50 millionths of an inch) and is repeatable to .0002" I just got it/used it today and it works great and repeated right on the money. It also looks like I'm gonna have to send my block back
IMO the non digital ones are a little eaier to use and set. I would reccomend the Mitutoyo if you want a nicer one. I paid $200 for the Fowler I got and for the price and range it has I am very pleased.
Old Mar 15, 2007 | 11:45 PM
Rocket's Avatar
Default Re: Checking my bore: Is this gauge ok? (Rosko)
$60 from Amazon.com
http://www.amazon.com/2-ENGINE...8QVES
$30 from Ebay
http://cgi.ebay.com/2-6-BEST-B...wItem
Dang, that some awesome tips!!
Eye Candy (pic from Amazon)
Old Mar 16, 2007 | 07:59 AM
Tippyman's Avatar
Ok, that's the kind I'm used to seeing.
Thanks alot man!
vinuneuro
23
Apr 17, 2009 08:22 PM
b20beast83
Apr 1, 2009 07:17 AM
RACEPAK
Welding / Fabrication
Jun 13, 2008 08:39 AM
scatuli
Apr 30, 2004 09:40 PM
