springs
Old Mar 13, 2007 | 07:21 PM
veritasaequatis's Avatar
Default springs
what springs from any other honda or acura car will fit an 87 crx si?
Old Mar 13, 2007 | 09:02 PM
Default Re: springs (veritasaequatis)
nothin ?
Old Mar 14, 2007 | 05:17 PM
still nothin ?cmon guys
Old Mar 20, 2007 | 12:49 PM
bump
Old Mar 20, 2007 | 12:55 PM
freakystyley_73's Avatar
Buy new ones, I think eibach makes springs for 1st gen rex. Do a google search. Are you looking to lower it?
Old Mar 23, 2007 | 10:49 PM
Default Re: (freakystyley_73)
yeah i fooled around on ebay and won an auction that was only for the rear springs which pissed me off royally but im looking to lower it anywhere from an inch to 2 inches
Old Mar 24, 2007 | 02:56 AM
1hgej1's Avatar
Default Re: (veritasaequatis)
Eibach does in fact make springs for that generation but it's only for the rear. It states that the front torsion bar is adjustable. You can buy aftermarket front torsion bars that will lower the front of the car about an 1" to an 1 1/4". I've found aftermarket front torsion bars at this website here: http://www.upgrademotoring.com...n.htm
You'd be best off getting the 24mm @ 204 lb spring rate torsion bars if you just use it as a street car. Then getting the Eibach springs for the rear. It'd be a 1" drop all around just about.
Old Mar 24, 2007 | 08:21 AM
jlicrx's Avatar
the only place it has springs is in the rear, with separate shocks - it does not have struts - 84-87 CRX/Civic and 86-89 Integras will work - the front has torsion bars which you can adjust under the car to lower it about 1" or a little more - if you want more, you need to remove the torsion bars and relocate the splines in the torque tube - since the rear uses a single "axle" and is not independent suspension, if you lower the rear you need an adjustable panhard bar in order to keep everything centered under the car
Old Mar 26, 2007 | 05:26 PM
Default Re: springs (jlicrx)
thanks guys u've helped a ton and chris thanks again man
alex14
31
Jan 30, 2011 11:03 AM
Thanks knightsport!
Dec 1, 2005 04:46 PM
gofastgsr
Mar 23, 2004 09:50 AM
crj_lll
Sep 10, 2003 09:39 PM
Racebrewer
Jun 24, 2002 05:41 AM
