transmission fluid on 90 Si transmission.
Old Mar 13, 2007 | 07:08 PM
baboracus's Avatar
Default transmission fluid on 90 Si transmission.
Where do you check the fluid in the transmission?? Also, what's the best type of fluid to put in there.
Old Mar 13, 2007 | 08:23 PM
Ermil's Avatar
Default Re: transmission fluid on 90 Si transmission. (baboracus)
Honda MTF & a bottle of GM Syncromesh
Old Mar 13, 2007 | 08:55 PM
Jarrat's Avatar
Default Re: transmission fluid on 90 Si transmission. (Ermil)
Just use the Honda MTF, if you don't have that, you can use 10-30w to get you dealership to get some, had to do that once, a long long time ago.
Old Mar 14, 2007 | 05:44 AM
cbags05's Avatar
so how do you check it?
Old Mar 14, 2007 | 05:56 AM
kageshin's Avatar
you can't really check the fluid level cause it ain't got a dipstick.
edit/ manual/stick only!
I would suggest just go ahead and drain the fluids out and refill it.
btw, you have to get down under the car to do it...pain in the *** job...
Old Mar 14, 2007 | 07:34 AM
ghost_ryder35's Avatar
make sure the car is level, and remove the fill plug on the transmission. Stick your finger in the whole, you should be able to feel fluid. If you can not you are low on fluid.
Old Mar 14, 2007 | 08:53 AM
VtecSyndrome's Avatar
Default Re: (cbags05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbags05 &raquo;</TD></TR><TR><TD CLASS="quote">so how do you check it?</TD></TR></TABLE>
Watch it when it drains out . Not hard to do so if your not sure about the last time is was changed just do it, it NEVER hurts to put in fresh NEW tranny fluid Just think about how often your motor oil is reccomended to be changed? doesn't it make since to also change your tranny fluid more often too? , after all it is just oil which breaks down over time (I change mine about every 15-20k just to be safe considering how hard I drive)
Old Mar 14, 2007 | 09:06 AM
Ermil's Avatar
A simple look in the FAQ revealed this -
http://crf50.no-ip.com/fourthg....html
CRAZY HUH!?!?!
Old Mar 14, 2007 | 12:03 PM
baboracus's Avatar
wait a second, my car manual said to puse SAE 10-30 OIL so i just grabbed some valvoline 10-30 and threw it in there? Did i read it wrong or what??
Old Mar 14, 2007 | 12:08 PM
wiZCo's Avatar
Stouts 'n' Scotch
It's okay to use the reccommended viscosity engine oil, but Honda MTF is just better. Don't ask me why it is, it just seems to keep noise down better and creates smoother shifts in my experience. Some people also swear by a combination of Honda MTF and Syncromesh.
Old Mar 14, 2007 | 12:14 PM
xotic_crx's Avatar
Default Re: transmission fluid on 90 Si transmission. (wiZCo)
What is syncromesh, and is it readily available at parts houses?
Old Mar 14, 2007 | 12:36 PM
Ermil's Avatar
Default Re: transmission fluid on 90 Si transmission. (xotic_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xotic_crx &raquo;</TD></TR><TR><TD CLASS="quote">What is syncromesh, and is it readily available at parts houses?</TD></TR></TABLE>
Go to a GM dealer and ask for "Synchromesh"
Old Mar 14, 2007 | 01:07 PM
xotic_crx's Avatar
thanks
Old Mar 14, 2007 | 01:38 PM
Ermil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xotic_crx &raquo;</TD></TR><TR><TD CLASS="quote">thanks</TD></TR></TABLE>
No problem. It really is the way to go.
Old Mar 14, 2007 | 01:54 PM
TehLonz's Avatar
ermil ftw?
greenquark
Aug 5, 2014 03:50 PM
singher01
Jul 25, 2008 10:19 AM
bc_psychocivic
Sep 4, 2003 10:32 PM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
