Dyno results and findings
Old Mar 13, 2007 | 05:31 PM
InvaderTrax's Avatar
Default Dyno results and findings
Today was the big day, but it didn't go like I had hoped. Here's what I went up with:
I/H/E
Magnaflow cat
12lb flywheel
64mm TB with matched intake
Crower stage 1 cams with adjustable gears
Fairly heavy 17" rims (didn't cheat and throw my light weight 15's on for the day)
I went down there with Team Blindside to tune the car. To hook up the wideband, we had to remove my muffler, so the videos I post later will be pretty loud. First two runs went fine, just establishing everything. Next run they tried to lean out my AF, which threw a CEL as soon as they touched it. There were unable to do any ECU tuning because of this. Right now I have a chipped P14 with an approximate chip. Anyway, after we gave up on that, we adjusted the gears, which in itself leaned it out a little, and gave me 15 more HP on the top, as well as a much beefier midrange (which was my goal, we could have had more on top if I wanted). In the end, I had 137 HP, 138 TQ with an AF of about 13. Now, this was on a Mustang dyno, so it's 17% lower than a dynojet. Now, just before we pulled it off, we did one last run with the muffler on back on and I lost almost 20 HP and TQ. So I learned two lessons today. There's a reason no one chips the P14, and Pacesetter really does suck. Anyway, graph and videos to come (uploading now)
Old Mar 13, 2007 | 05:35 PM
SnoMan's Avatar
what kind of motor do you have?
Old Mar 13, 2007 | 05:37 PM
kdt3's Avatar
get p28 or p72
H23 with 176k, 175 PSI on each cylinder
Old Mar 13, 2007 | 05:38 PM
alterdcreations's Avatar
Default Re: (SnoMan)
danm the stock muffler really soaks up hp
sure is quiet tho
Old Mar 13, 2007 | 05:40 PM
Oh, it's not stock. It's a 2.5" Pacesetter dual tip. I had heard horror stories, and it even felt like the car was weaker when I put it on, but I thought it was in my head. He also recommended a P06, but I think he forgot about the lack of support for my secondaries. Blindside mostly does turbo Hondas, where they usually remove the secondaries or get a whole new intake
Modified by InvaderTrax at 9:51 PM 3/13/2007
Old Mar 13, 2007 | 05:56 PM
GraphiteMW's Avatar
Default Re: (InvaderTrax)
You should add the 2.5" collector for your header to your next to do list
do you have a true 2.5" exhuast?
Old Mar 13, 2007 | 06:21 PM
Yup. Exhaust is 2.5" mandrel bent with the Magnaflow cat and 12" resonator. Anyway, here's the graph
Old Mar 14, 2007 | 04:49 AM
flyrod's Avatar
Thanks for sharing! There don't seem to be many H23 guys working on their engines. A P28 type ECU would give you more ability to tune, but those A/F don't look all that bad.
Old Mar 14, 2007 | 05:38 AM
luder94-ChrisA's Avatar
Default Re: Dyno results and findings (InvaderTrax)
Your #'s aren't that bad for a mustang dyno. If you use 15% (conservative) lower than a dynojet, then you come up with about 161 HP & 162 TQ if it was a dynojet. Most stock H23's with IHE are in the low 140's for HP. It must feel pretty decent for driving around town (ie. below 4500 rpm)
Old Mar 14, 2007 | 05:53 AM
PirateMcFred's Avatar
So when're the cams going in?
Pirate
Old Mar 14, 2007 | 08:05 AM
GraphiteMW's Avatar
Default Re: Dyno results and findings (PirateMcFred)
Hahah, yesss that's where us H23 boys gain the most. Our stock cams stop making power around 5,2000rpm
Old Mar 14, 2007 | 11:01 AM
Default Re: Dyno results and findings (GraphiteMW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">Hahah, yesss that's where us H23 boys gain the most. Our stock cams stop making power around 5,2000rpm </TD></TR></TABLE>
Work on the exhaust a little. You will pick up a little power after a characteristic H-Series dip at 5600ish rpm. Technically my OEM cams peaked at 6000rpm. Example:
http://www.we-todd-did-racing....A.GIF
Old Mar 14, 2007 | 11:42 AM
94Vtecluder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder94-ChrisA &raquo;</TD></TR><TR><TD CLASS="quote">Your #'s aren't that bad for a mustang dyno. If you use 15% (conservative) lower than a dynojet, then you come up with about 161 HP & 162 TQ if it was a dynojet. Most stock H23's with IHE are in the low 140's for HP. It must feel pretty decent for driving around town (ie. below 4500 rpm) </TD></TR></TABLE>
Stock H22's should dyno in that range, 155-165ish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">So when're the cams going in?
Pirate</TD></TR></TABLE>
Old Mar 14, 2007 | 12:18 PM
Default Re: Dyno results and findings (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, with a lot less torque down low
I've had both motors & H23 is still my favorite for driving around town
But my H22 kicks its butt on the racetrack
Old Mar 14, 2007 | 02:14 PM
Even before the tune I was schooling basically stock H22's and GSR hatches. Even one of those new Civic SI's
Old Mar 14, 2007 | 03:19 PM
95greenlude's Avatar
looks like good numbers.
i want to get a set of cams, to bump up the power a little.
p.s. my stock cams died at 5500 for me.
Old Mar 14, 2007 | 03:30 PM
McLude2nR's Avatar
what's your WHP goal br4h?
Old Mar 14, 2007 | 05:59 PM
Well, I was hoping for 150 Mustang HP, which would be about 175 dynojet, which is more or less 200 crank
Old Mar 14, 2007 | 06:06 PM
GraphiteMW's Avatar
Nice I am shooting for 190whp with my build. H23 of course. How much miles do you have your motor?
Old Mar 14, 2007 | 06:45 PM
McLude2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Well, I was hoping for 150 Mustang HP, which would be about 175 dynojet, which is more or less 200 crank</TD></TR></TABLE>
What kind of Intake Manifold do you have? I picked up some nice gains on my N/A integra w/ that and an ok tune. Or you could just throw some juice on that bish...
Old Mar 14, 2007 | 07:06 PM
It's a stock manifold with a 64mm maxbore.com TB and matched opening
Old Mar 14, 2007 | 07:11 PM
McLude2nR's Avatar
Does the stock H23 have secondary butterflies like the H22's? Or is it single stage? What kind of IM's do they make for the H23 anyways? Seems like theres some power just locked up in your tune as well.
Old Mar 14, 2007 | 07:27 PM
^yes it has secondaries...
As far as i know, there is only one aftermarket H23 intake manifold (obx) but i think Blacktrax sells some...
Old Mar 14, 2007 | 07:32 PM
GraphiteMW's Avatar
Default Re: (95greenlude)
Blacktrax sells some but I read the dyno's and I believe the guy lost some at the low range and gained it back up high. Better off just getting the oem im port and polished.
btw subscribed, some reason i am VERY attracted to all motor h23 builds. :D
