FS:F/R disc brake swap (95delsolsi) lowballers comein!!!!!!! $70!!!!!
Old Mar 13, 2007 | 05:23 PM
JCracer723's Avatar
Default FS:F/R disc brake swap (95delsolsi) lowballers comein!!!!!!! $70!!!!!
ok here is the deal... i resently did a complete overhaul on my 95delsol si. so i pretty much got front knuckles ( the small 9 inchers ) comeplete with calipers rotors and lines.. rear trainling arms with calipers, rotors and lines.. ( missing bolts )
now i think the bearings are bad. for the rear i got a pair of used 99 SI bearings that you can use. they seem fine before i changed them ( just wanted to go with all NEW parts )
the front bearings might also be going out. and the rotors are trashed...
so ONLY $70 bux.. . just want this stuff out of here.. PM me.. located in 626
NO DOWN TIME if you want to replace your bearings...
Old Mar 13, 2007 | 06:32 PM
JCracer723's Avatar
Default Re: FS:F/R disc brake swap (95delsolsi) lowballers comein!!!!!!! $70!!!!! (JCracer723)
JCracer723
Mar 19, 2007 07:23 PM
JCracer723
Mar 9, 2007 06:53 PM
Reelizmpro
Sep 22, 2006 10:07 PM
HKS accord
Oct 11, 2002 09:47 AM
Chugger
Oct 7, 2001 07:36 AM
