Type r intake fitting in a del sol???
Hey all, I decided to vouch for a new intake and retire my password one. I feel like a rookie again buying a new intake, but anyways. I want to go with an ARC induction box, comptech icebox, or an AEM v2. Has anyone used an intake for an ITR in a del sol? If so, what kind of fabricating had to be done for the best results? I know it's not going drop right in and fit like a glove
The type r intake manifold is a bolt on affiar. You will have to get a different IACV (off any integra and the ones on most single cams will work as well). Now as far as what is better the type r most likely will only yeild 2 more HP at the very end of the RPM limit of a B16 and will loose horsepower under the curve now that is on a stock B16. Good Luck
xavior66
Nov 28, 2003 08:02 AM
