'91 Accord Front Stabilizer Bar
Old Mar 13, 2007 | 04:38 PM
pittsf's Avatar
Default '91 Accord Front Stabilizer Bar
Anyone know if these are under such tension that would make it impractical for the owner (me) to replace the bushings at the ends?
The rubber bushings are wornout and I think it causes a severe vibration when hard braking - feels like a shimmy, it's so bad. To verify, I wrapped some shock cord around the bolt where the bushing was gone, and the vibration diminished considerabley.
It looks like the bolts on each end can be removed, the bushings replaced, and the bolt put back in. Maybe some tuning required to get the right tension when replacing?
Any information greatly appreciated.
Old Mar 13, 2007 | 04:46 PM
203Cree's Avatar
Default Re: '91 Accord Front Stabilizer Bar (pittsf)
Easiest way. Unload the suspension, meaning put the car on jackstands. Remove the bolts and replace the bushings. When installing the new bushings, tighten the hardware until the bushings start to compress. Adjust as need from there.
If it only happens under hard braking, I'd check the rotors too, as in all likely hood you've got a warped rotor as well.
VTEC_Viking
Suspension & Brakes
Nov 7, 2008 01:21 PM
hon da top
Dec 18, 2005 08:37 AM
knucklebuster
Jul 6, 2004 05:36 PM
RTW DC2R
Mar 21, 2003 09:21 AM
chili
Aug 7, 2002 01:34 PM
