Wiring Question (alarm related)
Old Mar 13, 2007 | 03:33 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Wiring Question (alarm related)
Hey fellas, haven't been on the boards in a while, really busy with school, but now that I'm on spring break, I've spent a little time with the R since it's been unusually nice out.
Anyways on to my question, it may need more detail so I will be happy to add if you request. When I bought my car (used) it had an alarm installed on it (a pretty cheap one at that), and I began removing it during my winter break. Now that I am back up and starting to drive it again, the wiring harness is still under the driver's side dash and needs to be removed.
Now, as with all alarm installs, wires are spliced into the original harness of the vehicle. It is spliced in really well and done correctly. Now that I removed the alarm "black box" where all the plugs to the alarm go into, I'm left with this nasty harness. I would like to cut it out and cap off the ends that are spliced in so it can sit nicely underneath the dash.
Below is a pic of the harness as it sits now and below that is an edited pic that shows which ones seem okay to cut.
***I think this should be in the audio/alarm etc. section, but I thought I would get more hits here and I know a number of you have been under the dash one time or another.
on to the pics
any tips are welcome
Old Mar 13, 2007 | 03:40 PM
TTZMatt's Avatar
Default Re: Wiring Question (rino924)
I'm not sure exactly what your question is? If you want to remove the harness for the alarm, I would recommend just cutting it out completely and then soldering the original wires back together. I would also recommend using heat shrink tubing over the soldered areas for a clean job.
Old Mar 13, 2007 | 03:43 PM
rino924's Avatar
Community Builder
Default Re: Wiring Question (TTZMatt)
My bad. The main question was, I didn't want to cut something and screw something up. Seems to always happen to me.
I did grab some heatshrink and have the soldering gun ready. Just want everything to sit nicely how it was stock under the dash
Old Mar 13, 2007 | 03:50 PM
TTZMatt's Avatar
Well as long as you know which wires are the for the alarm , you will be OK. I would definitely remove them completely(if you dont plan on re-installing the alarm) and just solder the stock wires back together as opposed to just cutting the alarm wires short and putting a cap on them.
Old Mar 13, 2007 | 04:10 PM
rino924's Avatar
Community Builder
alright, thanks a lot.
its just when it comes to electrical, i always freak out
Old Mar 13, 2007 | 04:16 PM
BMaDOHC's Avatar
there is probably a wire that goes to your ignition 12 volt on wire. This wire is usually completely cut when alarms are installed not just spliced into. you want to make sure the two ends come back together. everything else is just cutting out crap.
Old Mar 13, 2007 | 04:46 PM
rino924's Avatar
Community Builder
Default Re: Wiring Question (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote">there is probably a wire that goes to your ignition 12 volt on wire. This wire is usually completely cut when alarms are installed not just spliced into. you want to make sure the two ends come back together. everything else is just cutting out crap.</TD></TR></TABLE>
ill update as I go through. Right now im just mapping everything out and will post up if I need any more advising
Old Mar 13, 2007 | 05:02 PM
Cheeze's Avatar
If you wanted to save time and trouble of soldering..i would just cut the area you circled and use teh heat shrink to where it would hang off the wire just a lil bit for each wire you're cuttin..then i would wrap them with electrical tape individually..once that'z done, I would wrap all the wires together as 1 big bundle.. doesnt' have to be completly covered in electrical tape..just enough to keep them all in one like a snake. Good Luck!
Old Mar 13, 2007 | 05:43 PM
rino924's Avatar
Community Builder
Default Re: (Cheeze)
well, I overcome my first "major" electrical feat.
I soldered everything and now it's back to stock specs
thanks a lot to the guys above
Don Jefe
Nov 26, 2008 01:39 PM
dragonfly2k3
Dec 19, 2007 06:25 PM
import810
Audio / Security / Video
10
Oct 18, 2005 10:58 AM
92LudeSI
13
Mar 17, 2005 04:47 PM
CaMiKaZi
Apr 21, 2003 01:30 PM
