will f series injectors work in my h22?
Old Mar 13, 2007 | 03:25 PM
crfr230's Avatar
Default will f series injectors work in my h22?
will f series injectors work in my h22? i was told they would work but my car has no fuel on the spark plugs when pull them out. there is pressure and fuel in the rail but i dont know if the injectors are working?
Old Mar 13, 2007 | 06:08 PM
jdmlude_dude's Avatar
Default Re: will f series injectors work in my h22? (crfr230)
yeah but they are too small, it will be lean, correct me if i am wrong
Old Mar 13, 2007 | 10:21 PM
91SI92's Avatar
i don't think that they are big enough. i think the92-96 H22 comes with about 345cc injectors n the 97 & up are about 280cc. u also have to kno if they are the "peak and hold type" or the "saturated" type. this info is off the PGMFI site. check it out when u get some time. here's the link http://www.robietherobot.com/s...e.htm
Old Mar 14, 2007 | 09:57 AM
prelittlelude's Avatar
any f series injector is a 240cc , the h22a1s had 345cc and h22a4 has 290cc
if you plan to run F series injectors you need to tune, or bump up your fuel presure.
Dravenm4
Aug 17, 2009 03:07 PM
jdmbeegee
Dec 5, 2006 10:46 AM
JDM_SOHC
Oct 8, 2005 05:04 PM
egH22
Mar 16, 2005 12:44 PM
