no gas
Old Mar 13, 2007 | 01:22 PM
shackler's Avatar
Default no gas
I just swapped my b16a into my 88 crx hf. I am not getting any fuel to the filter, i swapped the pump changed the main relay, what else could it be im stumped and want this baby running!!!
Old Mar 13, 2007 | 01:24 PM
Ermil's Avatar
Default Re: no gas (shackler)
Did ya check the fuse? Check for power to the pump?
Old Mar 13, 2007 | 01:37 PM
Oregon's Avatar
* B A N N E D *
Default Re: no gas (Ermil)
How many miles on the body of the HF ? main relay
Old Mar 13, 2007 | 02:13 PM
shackler's Avatar
Default Re: no gas (Oregon)
209k on the chassis i swapped the main relay it clicks when ignition is turned and i cant tell if the pump is turning on or not I'm by myself but i just bought this pump, so I dont think it could be it.
Old Mar 13, 2007 | 02:16 PM
xlr8_si's Avatar
hmm this sounds familiar. exact thing happen with my friend hatch swap and it was a ground cable.
Old Mar 13, 2007 | 02:35 PM
Ermil's Avatar
Default Re: no gas (xlr8_si)
Did you check for power to the pump?
Old Mar 13, 2007 | 02:37 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlr8_si &raquo;</TD></TR><TR><TD CLASS="quote">hmm this sounds familiar. exact thing happen with my friend hatch swap and it was a ground cable. </TD></TR></TABLE>
i had the same problem. check all your grounds, then check them again
Old Mar 13, 2007 | 09:24 PM
shackler's Avatar
Default Re: no gas (garageEF)
does any have any diagrams for all the grounds??
Modified by shackler at 5:10 PM 3/14/2007
Old Mar 14, 2007 | 04:11 PM
shackler's Avatar
so i was checking the grounds today and i was wondering is the ground for the battery wire also run the the transmission just below the battery?
SpoonEk253
41
Oct 3, 2022 03:21 PM
thakid
Dec 27, 2010 06:08 AM
BBY98EX
Jul 20, 2008 12:06 PM
96civic_ek4
Dec 7, 2007 12:28 PM
superbeastcrx
Jun 6, 2006 11:21 AM
