Forbiden...zzzz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iboot »</TD></TR><TR><TD CLASS="quote">Forbiden forgot about us 5th gen owners... I've been waiting so long for the short shifter since i've heard nothing but good things about the 4th gen prelude short throw. What's the dealio ?</TD></TR></TABLE>
he's in his early 20's, has a job, goes to school. He's got alot on his plate.
u can always do what i did and put the 4th gen shifter in your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">u can always do what i did and put the 4th gen shifter in your car.
That's what I'd do it I had a 5th gen.
</TD></TR></TABLE>That's what I'd do it I had a 5th gen.
Don't you have to cut up the console to make it fit though? Don't you also need to use the 4th gen shifter plate/bracket and shift cable also?
I've been waiting too and have thought about just buying the 4th gen shifter but I've read some bad things about it....like chopping your console
Did you have to do any of this? Cause if that is not true then I will totally consider it.
</TD></TR></TABLE>Don't you have to cut up the console to make it fit though? Don't you also need to use the 4th gen shifter plate/bracket and shift cable also?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAN97SH »</TD></TR><TR><TD CLASS="quote">
Did you have to do any of this? Cause if that is not true then I will totally consider it.</TD></TR></TABLE>
i cant talk about the 5th gen but when i put it in my 4th gen you have to trim back the plastic under the console. when you go to 5th gear it will hit it. but its no biggie. you can even see were you have to trim the plastic back because it is under the console. but as far as bad things i have had no problems with it and i like it a lot. highly reccomend...
yeah, i just installed my FM shortshifter and plate.
the plate looks really clean.
but im havin some issues with the shifter.
and yes, you gotta trim the inside of the console. but not alot just so it doesn't hit the console when you put it in 1,3,5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden »</TD></TR><TR><TD CLASS="quote">Who said I go to school? lol I've been done almost 2 years. School is for fools! hah JK
shaylude...whats going on with it? Shouldn't have any troubles at all putting it in your 4gen!</TD></TR></TABLE>
you suck. I forget how long its been since i last saw you, lol
I guess that means no 5th gen shorty huh?
Guest
Posts: n/a
thats how mine is set up
</TD></TR></TABLE>thats how mine is set up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gargantuan »</TD></TR><TR><TD CLASS="quote">I guess that means no 5th gen shorty huh?</TD></TR></TABLE>
Its still the next project on the plate. I've got someone who is interested in the business that might help me make some things happen. We'll see.
