Looking for good speakers 110watts rms at 2ohms
Old Mar 13, 2007 | 08:08 AM
mrdeadman's Avatar
They let me pick
Default Looking for good speakers 110watts rms at 2ohms
Components for the front and 2 ways/midbasses for the back. I know the kappas are but do you know of any others that have real sq? Thanks, they don't have to be exactly 110watts rms, just no more than that. Or 55watts rms at 4 ohms.
Modified by mrdeadman at 12:34 PM 3/14/2007
Old Mar 13, 2007 | 02:40 PM
EBP_SI's Avatar
Default Re: Looking for good speakers 110watts rms at 2ohms (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">Components for the front and 2 ways/midbasses for the back. I know the kappas are but do you know of any others that have real sq? Thanks, they don't have to be exactly 110watts rms, just no more than that. </TD></TR></TABLE>
image dynamics makes some 2ohm component sets i believe. i would also recomment putting the midbass drivers up front.
just curious as to why you're shopping by power specs?
Old Mar 14, 2007 | 11:33 AM
mrdeadman's Avatar
They let me pick
Default Re: Looking for good speakers 110watts rms at 2ohms (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
just curious as to why you're shopping by power specs?</TD></TR></TABLE>
Components sets come with midbasses...
The amp I bought to power my sub, has 5 channels, and those are the specs of the amp because I'm going to amp my speakers. Also: the speakers can be 55rms into 4 ohms.
Old Mar 14, 2007 | 01:53 PM
EBP_SI's Avatar
Components sets come with midbasses... </TD></TR></TABLE>
thanks for the tip but they dont come with midbass drivers unless you go with a 3way component set. What i was suggesting is to install your component set in the front and then add the midbass drivers to the front stage too. you shouldnt have any speakers behind you.
Old Mar 14, 2007 | 03:02 PM
mrdeadman's Avatar
They let me pick
thanks for the tip but they dont come with midbass drivers unless you go with a 3way component set. What i was suggesting is to install your component set in the front and then add the midbass drivers to the front stage too. you shouldnt have any speakers behind you. </TD></TR></TABLE>
Interesting. Why is this? Doesn't it have something to do with sound stage/dynamics or something? Also: Do you have a link to a information database about speakers? As in the materials of the speaker and the materials' affect on sq? Thanks for the info btw.
Old Mar 14, 2007 | 03:39 PM
EBP_SI's Avatar
Interesting. Why is this? Doesn't it have something to do with sound stage/dynamics or something? Also: </TD></TR></TABLE>
well primarily you have to look at how the music is recorded. cd's are stereo meaning left and right. when you start playing the information recorded on the left channel from a source in front of you and behind you the information becomed confusing. some people thinks this is cool and its "surround sound" these people are morons. what you will not have is good center focus and a nice wide soundstage. you can also look at it like this. why spend X amount of money on 2 sets of components when you can spend that same amount on one set of components and get something thats much higher quality. theres a bunch of reasons why you would opt not to put in rear speakers but to list them would take days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a link to a information database about speakers? As in the materials of the speaker and the materials' affect on sq? Thanks for the info btw.</TD></TR></TABLE>
nope. i dont know if such a thing could exist. for example, pioneer has speakers made of kevlar, so does B&W but they by no means sound the same. theres a ton of factors that affect how a speaker performs. the only way to shop is just to listen to them. i mean you wouldnt buy a tv without looking at the picture quality.
Old Mar 14, 2007 | 04:35 PM
mrdeadman's Avatar
They let me pick
nope. i dont know if such a thing could exist. for example, pioneer has speakers made of kevlar, so does B&W but they by no means sound the same. theres a ton of factors that affect how a speaker performs. the only way to shop is just to listen to them. i mean you wouldnt buy a tv without looking at the picture quality. </TD></TR></TABLE>
I'll be buying my speakers off the internet because no one carries the stuff I want. All they have are alpine, eclipse and pioneer. Nothing of superior sound quality like infinity or mb quart or nakamichi ... so I was just looking for opinions.
Old Mar 14, 2007 | 09:24 PM
EBP_SI's Avatar
hmm. well how much are you looking to spend?
Old Mar 14, 2007 | 10:10 PM
rcurley55's Avatar
New User
thanks for the tip but they dont come with midbass drivers unless you go with a 3way component set. </TD></TR></TABLE>
if the larger driver in a 2-way comp set plays midbass frequencies (commonly know as 80Hz-250Hz in a car) - then you can call them midbasses - no need to play semantics
Old Mar 14, 2007 | 10:28 PM
EBP_SI's Avatar
Default Re: Looking for good speakers 110watts rms at 2ohms (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">
if the larger driver in a 2-way comp set plays midbass frequencies (commonly know as 80Hz-250Hz in a car) - then you can call them midbasses - no need to play semantics</TD></TR></TABLE>
but in theory and to avoid confusion wouldnt it be a midrange speaker? i mean a midbass speaker is only going to play that narrow range and when people talk about midbass its usually a dedicated driver.
Old Mar 15, 2007 | 04:50 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">hmm. well how much are you looking to spend?</TD></TR></TABLE>
About $200 on the front components. Less is always good. Just for clarification, a set like this: http://www.onlinecarstereo.com...15366
I don't suppose there's any way I could wire a set of speakers to a 2 ohm load without screwing up the channels right?
Old Mar 15, 2007 | 05:29 AM
fcm's Avatar
fcm
Old Fart
Looks to me like you have found a set of 2 ohm components for under $200. 94
PS I assume tuo have an am that is 110W into 2 ohms and 55W into 4 ohms.
Old Mar 15, 2007 | 07:56 AM
MilanoCivic97's Avatar
Default Re: Looking for good speakers 110watts rms at 2ohms (fcm)
I'll be buying my speakers off the internet because no one carries the stuff I want. All they have are alpine, eclipse and pioneer. Nothing of superior sound quality like infinity or mb quart or nakamichi ... so I was just looking for opinions.</TD></TR></TABLE>
FYI: Alpine &gt; Infinity. I've extensively listened to both, but thats just my preference.
Old Mar 15, 2007 | 10:20 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Looks to me like you have found a set of 2 ohm components for under $200. 94
PS I assume tuo have an am that is 110W into 2 ohms and 55W into 4 ohms.</TD></TR></TABLE>
I do.
Anyone know anything about the orion components that are the 3ohms?
mr poo
Audio / Security / Video
Apr 14, 2007 05:27 PM
pbizzlegsr
Nov 2, 2006 01:18 PM
Options
Apr 17, 2006 05:40 PM
youraquickone
16
Jun 17, 2005 03:20 PM
SLR SKiLLZ
Jan 2, 2004 10:51 PM
