h tranny
Old Mar 13, 2007 | 07:18 AM
ludecrasy87's Avatar
Default h tranny
I know that the h and f serie trannys are interchange able.
Now i was told lets say someone with f22b2 stock and the other the same stock the only difference is that the other person has h22 tranny, Now is their an actual advantage in this point?
If so wat is it? Like is the redline increase? Or does it stay the same in regular accords 96 lx?
Like the accord's redline is in the 5's now will it go higher just switchin trannies, also not the lsd one the plain one ?
Old Mar 13, 2007 | 07:23 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: h tranny (ludecrasy87)
redline has to do with the engine, not the tranny. Changing the tranny will not affect redline.
The H22 tranny has shorter gears than the F22 tranny so this will help to accelerate a bit faster.
Old Mar 13, 2007 | 09:32 AM
turboH22Aakkord's Avatar
Default Re: h tranny (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">redline has to do with the engine, not the tranny. Changing the tranny will not affect redline.
The H22 tranny has shorter gears than the F22 tranny so this will help to accelerate a bit faster.</TD></TR></TABLE>
true, but the f tranny has its advantages to... like for example, if you plan on boosting the motor in the future with the f-tranny it will alow you to stay in the gears longer alowing you to keep the engine under boost as well.
Old Mar 13, 2007 | 09:40 AM
H-T Order of Merit
Default Re: h tranny (turboH22Aakkord)
well, I thought we were only talking about the advantage one stock car with a H22 tranny would have, if any, over the same stock car with a F22 tranny? not the pro and cons of each tranny?
mdj_ge
Dec 22, 2004 06:34 PM
Siegfried
May 16, 2004 02:17 AM
juicedh22
Aug 6, 2003 08:37 PM
