poormans type-r setups
Old Mar 13, 2007 | 12:26 AM
SuperTomcat's Avatar
Default poormans type-r setups
im looking for dyno charts on the poormans type-r with i,h,e. ive tried to search and nothing comes up with any charts. if anybody is runing the setup how much hp are you making and where are you reving it out to. thanx alot for the help
Old Mar 13, 2007 | 06:04 AM
jay_cue's Avatar
Default Re: poormans type-r setups (SuperTomcat)
look through the 1.8 liter build thread
https://honda-tech.com/zerothread?id=1263436
not all are poorman type r setups, but there are many in there.
Old Mar 13, 2007 | 02:44 PM
EK Josh's Avatar
Default Re: poormans type-r setups (jay_cue)
I don't have a dyno chart because I'm at work, but my poorman made 184/135 with ITR cams, valvetrain, pistons, intake manifold, passwordjdm carbon fiber intake (J's Racing knockoff), dc "jdm" 4-1 ceramic header, and a 2.5" kteller exhaust.
Old Mar 13, 2007 | 05:38 PM
Default Re: poormans type-r setups (EK Josh)
thanx for the imput man but without the type-r piston and using the stock gsr short block do you think it would make about 170-180whp. i was thinking about getting a spoon or mugen headgasket do you think it would make similar hp. also do you have a.i.m if so hit me up at ardoch
Old Mar 13, 2007 | 05:49 PM
allmotorcrx415's Avatar
i have a poor man type r with a stock bottom end and im running 13.7 with street tires! its untuned too!
Old Mar 13, 2007 | 06:32 PM
Default Re: poormans type-r setups (allmotorcrx415)
anybody else have this setup and if so what tranny are you using and what is your setup.
Old Mar 13, 2007 | 06:40 PM
im using a 00 civic si b16 hydro tranny! i got a b16 head with a b18c1 block stock piston! i got the blox type a cams! rc 310 injectors, comptech header...
Old Mar 13, 2007 | 08:09 PM
The-Black-Bomb's Avatar
My brother has gsr block, ls crank, ls rods. usdm b16 piston. B16 head,valves,springs and retainers. Stock gsr cams Skunk2 IM. A b16 tranny, IHE. It made 172hp and 129tq and went 13.3@103.5 beaver springs
Old Mar 14, 2007 | 12:15 AM
Default Re: (The-Black-Bomb)
thanx for the input guys. keep them coming
Old Mar 15, 2007 | 01:02 AM
Default Re: (SuperTomcat)
i was talking to my cousin and he has a 94 ls integra and he just did a poorman type-r swap and he kept his ls tranny. i was wondering do you thik that tranny is that bad for him and do you think the motor will stay in vtec because his redline is set at 8400 and his vtec kicks in at 5500. its not a drag car its his daily driver and a auto-x/roadracing a few times a month. thanx for the responds guys keep them coming
Old Mar 15, 2007 | 01:47 AM
outtacontrolsol's Avatar
Tell him to junk that LS tranny as fast as he can uninstall it from that car. That is the least desirable of all B-Series trannys out there, because the gear ratios are so long. As a DD it nets good mpg, but thats about it. On the street it will appear slower than it really should be, and on the autocross it will be a salted slug. Worst possible tranny for autocross. For the money, I would get my hands on a Y21 B16 tranny. JDM models come with a built in LSD and a 4.400 final drive . If he is truly ballin though, gotta go with an ITR tranny, LSD and 4.7 final drive. You'll have to tell him to be easy on the throttle or he'll spin all the way through 3rd gear .
Old Mar 15, 2007 | 05:35 AM
Default Re: (outtacontrolsol)
he would dump the tranny but he kinda did it on a buget and used the tranny. he's looking for a gsr tranny or a gsr tranny later. all i was wondering is that tranny going to keep his car in vtec when he shifts. anybody on here every use that tranny in a lsvtec or anything?
Old Mar 15, 2007 | 07:38 AM
SkoundrelUSA's Avatar
cute little bastard
Mustang Dyno
setup:
https://honda-tech.com/zerothread?id=1869088
Old Mar 15, 2007 | 08:35 AM
one slow coupe's Avatar
Default Re: (SkoundrelUSA)
I had a pretty much oem lsvtec setup..
it was a ls crank
stock ls rods with arp rod bolts
b16 pistons
b16 head milled .036"
itr springs retainers
97 spec JDM ITR cams
AEBS intkake mani
shitty dc sports header
2.5 " custom exhaust
went 13.87 on some worn the expletive out drag radials in my heavy *** coupe
-kev
Old Mar 15, 2007 | 08:38 AM
Default Re: (one slow coupe)
oh yeah I never made it to a dyno but I was on a shitty street tune too. I was guessing somewhere around the 185-190whp mark.
-kev
Old Mar 15, 2007 | 02:53 PM
thanx for all the input guys but what trannys are yall runing,because as i stated earlier my cousin has a poormans type-r but he's still using the ls tranny. my question is do you think the tranny would keep him in vtec if the engagment point it set for the stock 5500. btw his redlaine is 8400 if thats any help
Old Mar 15, 2007 | 03:12 PM
.Grimace's Avatar
footwork mastery
i don't think it would keep it in vtec. there was a car in my area with that tranny on a similar setup and you could hear it fall out of vtec.
jceltalentoso
K Series
Feb 28, 2014 06:34 AM
BMo Tuning
13
Feb 7, 2008 12:42 PM
nokturnal_munkeeboy
40
Jun 26, 2007 04:43 PM
RACER2BE
15
Jun 25, 2005 11:18 AM
DA9teg93
May 8, 2005 05:13 PM
