Red H Emblem...
Hey,
Just wondering who here has installed the red H [rear]. I got my stock one off but I realized that the red H has pegs that wont line up with the holes on the car. Is this normal?
Just one? It seems like none of them fit but I'm not sure. I guess I could just break'em both off and let the tape do it's job.
How does the front one work? Is it the same deal or does it actually fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Japan Domestic »</TD></TR><TR><TD CLASS="quote">75701-S6M-Z01
Is that the front or the rear??
</TD></TR></TABLE>Is that the front or the rear??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamesBizzle »</TD></TR><TR><TD CLASS="quote">front's the same deal. you may want to sand the two little nipples so that the emblem can sit flush. same for the rear.</TD></TR></TABLE>
Sounds painful.
I'm thinking about getting some red H's for mine, I'm just not sure how it'll look on VBP.
Sounds painful.
I never sanded down the front grill for the install. You may want to double check. I just added a couple of peices of 3M double sided tape and it worked fine. The front emblem doesn't fit like the oem one, it seems to be a bit smaller, so just center it and no one should be able to tell the difference
Just curious, on the rear emblem did you remove the wiper assembly and all that, or did you just happen to get to it from underneath?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fitfreak3 »</TD></TR><TR><TD CLASS="quote">
Just curious, on the rear emblem did you remove the wiper assembly and all that, or did you just happen to get to it from underneath?</TD></TR></TABLE>
For the rear I tried to remove all the wiper stuff and take out the whole piece but after I got the wiper motor off I couldn't pop out the clips... so I just took a credit card and slipped it under the H and then broke it off with a knife. Worked like a charm.
For the front, I sanded down the grill and i got the emblem centered fine but for some reason I think it's going to come off. Just doesnt feel like its fully on there. I think I need some glue or something. Doesnt the 3M tape keep it from sitting flush on the grill?
I used extra 3M tape for the rear and the front. It's been 5 months since I put them on and they're still holding up.
And for others intersted in doing this mod it the future, there's an easier way to remove the rear emblem. All you have to do is open the hatch and look up to where the hatch handle and the licence plate lights are located. You'll see the pegs for the emblem. get a flat head screw driver and put the tip of it to one of the clips then smack the bottom of the screwdriver. This will break the peg. Repeat for the other peg then your done. Easy as that.
Anyone got some close up pics of the front emblem installed?
Also, is the double sided tape that comes with the emblem enough to hold it or is more necessary?
Any pointers on how to remove the front emblem?
Since it'll be about 80 degrees here today, I'll probably wash my car. If I do I'll take a picture of the emblem for you
btw, I didn't have to use anything else to stick the emblem on there. I was kind of nervous about it at first but it seems to be holding on quite well... for the time being.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonGD1 »</TD></TR><TR><TD CLASS="quote">looking good
indeed
</TD></TR></TABLE>indeed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by retroFIT »</TD></TR><TR><TD CLASS="quote">Anyone got some close up pics of the front emblem installed?
Any pointers on how to remove the front emblem?</TD></TR></TABLE>
Not sure if the double sided tape on the emblem was enough or not but I diddn't want to find out by it just falling off, or "disappearing" on me.
When I removed my front OEM emblem, I just used a flat head screwdriver to pry it off. I wrapped the screw driver in a shop towwel though so not to scratch the plastic behind the emblem.
hope this helps
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrRabbit87 »</TD></TR><TR><TD CLASS="quote">i think el is gaye......
lets play somefootball
Go play in the Civic forum
</TD></TR></TABLE>Go play in the Civic forum
I just used a credit card type object [I used an old gift card] You might break the edges of the card so be careful which card you use. I just put the card under a corner of the emblem and worked the card under the whole side of the emblem. They rip off quite easily.
