Tail lights
just use a lil gas(yes gas-o-line) and rub it with a cloth.. it'll take ages but it wont scatch or fade ur stock brakelights.. and if they do.. u can use plastic polish or rubbing compound
I wouldn't recommend sanding them. I did that after awhile when I was repainting my old tails to remove the paint and when they finally got back to the stock look they were scratched and faded. If it is the first time painting just put a few coats of red on and then clear coat.
i used this paint that people use for RC cars, the look is not like the civic above, its clear, sort of like OEM and its not thick.... go to a hobby shop and ask for it. it cost about 4 bucks a can(5oz), but all you need is one. make sure you put like 4-5 dpending on the color on the rest of you tailights
That's the same paint I use, Testors brand Transparent Candy-Apple Red for models. It comes out looking 100% OEM red, so I don't know what other color you'd want?
Listen, I'm the guy whose post you saw. If you want it to be easy to apply without getting runs, just sand it down. It takes no time at all and will make the paint take to the lights MUCH better. If you ever want to go back to stock, just sand off the spray paint and apply a few layers of clear coat. They will look stock again (I did this a while back so I know...and yes, it was surprising but VERY true, trust me).
You said something about those guys tails not looking glossy like OEM, right? Well take a look at mine...they are glossy. I used a cherry red transparent stained glass hobby paint by Krylon. I got it at Walmart in the crafts section.
Sure it was a good clearcoat? Even with just 1 or 2 light layers I get a very brilliant shine, I add like 4-5 coats just to be safe. Try something like Krylon's outdoor use CC, heavy duty stuff, shines really good.
I am pretty sure it was. It definitely got shiner when I used the clearcoat, but never a shine like the OEM lights. Oh well, it doesn't really matter anymore anyway, I got the red/clears now.
if you want them to shine, after you paint the lights use some car polish and a soft rag and polish them before clear coating them. this will take alot of the cloudiness away and make them look more factory. I've done this on the last 2 cars i've owned and they are still looking good.
snatch
Nov 9, 2005 12:35 PM
