crower stg. 3 camshafts
Old Mar 12, 2007 | 08:23 PM
94hatchvx's Avatar
Default crower stg. 3 camshafts
i purchased some crower stg 3 camshafts for my b16. i already have crower retainers and omni valves. i know the lobes on the camshafts require quite a strong spring with a good coil rate. i have type r dual valve springs right now. can i use them if not which valve spring should i go with?
Old Mar 12, 2007 | 08:31 PM
frostyrb's Avatar
Default Re: crower stg. 3 camshafts (94hatchvx)
I believe the cam card should tell you what spring pressures they want you to use. Did you recieve a cam card with your crowers?
punkracer
Jun 24, 2010 09:11 PM
Amped
Aug 30, 2006 04:33 PM
