Why is my Car running rich ???
Old Mar 12, 2007 | 07:18 PM
slow_srt's Avatar
Default Why is my Car running rich ???
I have a 90 Si Hatch, A6/Z6 Mini-me using all the A6 fuel delivery and intake components. Just switched to a Z6 head, gasket, belt, and camgear. I can't get the thing to quit smoking, At first I thought it was burning oil so I tore it apart and replaced all the valve seals.. The compression on the engine is 170 in all cylinders. It is not using any oil or coolant. It does not seem to smoke at idle but pours out the black/brown smoke when revved up. I had a bad ECU so I got another PM6 out of an 88 Si wich I'm assuming is the same.... What do I do now?? Keep throwing parts at it? The air filter is new, I tried running it without the 02 sensor plugged in to see if that made a difference. Do I try a fuel filter ? New 02 sensor? My plugs all look like this
Old Mar 12, 2007 | 09:22 PM
black88si's Avatar
Default Re: Why is my Car running rich ??? (slow_srt)
Replace your O2 sensor and plugs. Are your vacuum lines routed properly?
Old Mar 12, 2007 | 09:38 PM
slow_srt's Avatar
Default Re: Why is my Car running rich ??? (black88si)
Vacuum lines are all correct. I'll try an 02 sensor and plugs tomarrow... Thanks.
Old Mar 13, 2007 | 05:46 AM
garageEF's Avatar
any codes?
Old Mar 13, 2007 | 05:31 PM
slow_srt's Avatar
Default Re: Why is my Car running rich ??? (garageEF)
No codes.. Just replaced the 02 sensor and put in new plugs. Still no change.
Modified by slow_srt at 7:29 PM 3/13/2007
Old Mar 13, 2007 | 07:47 PM
digitally_remastered's Avatar
doesnt the iat sensor have something to do with how rich/lean the car runs also?
Old Mar 13, 2007 | 08:29 PM
Tippyman's Avatar
I would say that the timing is fucked up causing it to run rich. My timing is retarded three degrees and I am running a little rich. Maybe you're even more off than that,
Old Mar 13, 2007 | 09:34 PM
slow_srt's Avatar
Default Re: (Tippyman)
I set ignition timing with the wires jumped like the manual says. Its dead on. Cam timing is also perfect. I have checked both it seems like a thousand times.. I dunno. I"m going to drive the car tomarrow and see if it gets any better..
Old Mar 13, 2007 | 09:48 PM
abnaasefmb's Avatar
Default Re: (slow_srt)
your plugs give you a snapshot of time. make sure you engine is warmed up all the way and and drive it then pull the plugs.
Old Mar 14, 2007 | 03:15 AM
janz3n's Avatar
Default Re: (abnaasefmb)
your using a si ecu (pm6) for a mini me swap? whats the point of the vtec head then? and would the wrong ecu have anything to do with it?
Old Mar 14, 2007 | 07:57 AM
1991hb's Avatar
maybe you should try using a P28 ECU...that's what your suppose to use since you gots a vtec head
Old Mar 14, 2007 | 05:34 PM
slow_srt's Avatar
Default Re: (1991hb)
Yes I understand to best way to do the mini me is with the correct ecu. Or you can do it ghetto and use a rpm activated switch. Still would not make the car run rich. But who knows.
Old Mar 14, 2007 | 07:45 PM
abnaasefmb's Avatar
go to pgmfi.org and read "maps"
sorry i'm not up on sohc engines but i'm sure if your running vtec you will need both high and low cam maps.
Alex_S
Apr 29, 2013 05:03 AM
Bowl_of_Rice
Jun 17, 2011 09:23 PM
Maireeka
Mar 1, 2007 07:16 AM
sexyrex
Sep 25, 2006 07:06 PM
yz125rider21
12
Jul 20, 2006 12:58 AM
