crx suspension question
Old Mar 12, 2007 | 06:46 PM
jaredvabeach's Avatar
Default crx suspension question
i ordered some kyb gr2's and i did not read the fine print which said 88 crx only,i have a 89 crx and i am curious to know if maybe the struts will fit,i would like to know before i open the box and try to put them on and void the warranty/return
please anybody who knows for sure let me know,thanks alot
Old Mar 12, 2007 | 07:00 PM
h224thgensedan's Avatar
the rear lower control arms are different
Old Mar 12, 2007 | 07:05 PM
harmonator84's Avatar
Default Re: (h224thgensedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h224thgensedan &raquo;</TD></TR><TR><TD CLASS="quote">the rear lower control arms are different</TD></TR></TABLE>
Yep he is right. The only difference between an 88 and 89-91 is the LCA"lower control arm". You could either try buying a lca or just send the kit back.
Old Mar 12, 2007 | 07:52 PM
freakystyley_73's Avatar
That's unfortunate news.
It's annoying that Honda did that, the '90 Si LCA's and the '91 DX LCA's are different too. 91 DX don't connect to the sway bar; so i had mine fabricated so it did.
Old Mar 12, 2007 | 08:06 PM
BlueRex1020's Avatar
Default Re: (freakystyley_73)
na bro 88 is different...just send em back n get the right ones..
Old Mar 12, 2007 | 08:07 PM
Default Re: (BlueRex1020)
I have an extra LCA I would sell but I kinda wanted to sell them with the suspension.
Old Mar 13, 2007 | 05:37 AM
actually i have friend that will probly sell his extra set of factory ones. ill talk to him after i get off of work if you want
Old Mar 13, 2007 | 05:44 AM
garageEF's Avatar
dont put 88 control arms on
just send the struts back and get the correct ones.
Old Mar 13, 2007 | 05:48 AM
wm07's Avatar
Default Re: (garageEF)
y not? the 88 arms are actually the better designed arms for performance driving.
Old Mar 13, 2007 | 05:59 AM
Default Re: (wm07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm07 &raquo;</TD></TR><TR><TD CLASS="quote">y not? the 88 arms are actually the better designed arms for performance driving.</TD></TR></TABLE>
He is right!
Old Mar 13, 2007 | 06:05 AM
garageEF's Avatar
Default Re: (wm07)
not worth replacing factory control arms with arguably better factory arms when he can just get the right struts for his car.
Old Mar 13, 2007 | 05:00 PM
Tyson's Avatar
Default Re: (wm07)
the "performance" of the two is exactly the same.
the mount the same way. they have the same dimensions between inner nad outer bushings. no difference other than shock mounting.
hndakd
Jul 24, 2012 10:43 PM
db8db8db8
Oct 16, 2009 04:35 PM
i_VTEC
Suspension & Brakes
10
Jan 5, 2009 01:45 PM
cbp_crx
Apr 19, 2006 07:41 PM
ecsahs3
Jul 7, 2004 10:59 PM
