'91 speedo drops to zero while driving
Old Mar 12, 2007 | 05:31 PM
91POSAccord's Avatar
Default '91 speedo drops to zero while driving
Hi all,
Glad I found this site. I hope you can help. I tried searching for previous topics, but could find the right key words to narrow down a good search, so here goes...
I recently picked up a 91 Accord LX. It recently started having a problem where I'll be driving along and the speedometer drops to zero. It will bounce around sometimes, but usually adjusts back to my current speed. Often times if it drops for long enough or bounces around enough, it will trigger the "S" light to start blinking. Tonight the "Check Engine" light came on too. If I stop the engine and restart the car, the lights will go off.
Driving or speed doesn't seem to actually be affected by this behavior, for what I can tell.
Thanks in advance.
Old Mar 12, 2007 | 06:09 PM
Chiovnidca's Avatar
Default Re: '91 speedo drops to zero while driving (91POSAccord)
What trouble code does it have stored? It's most likely a bad speed sensor.
Old Mar 12, 2007 | 06:21 PM
BLKFLSH's Avatar
Click on the link, then scroll down to where is says retrieving trouble codes for 91 Accord. It will explain how to get the codes. Good luck.
http://www.troublecodes.net/honda/
Next is the link for VSS (vehicle speed sensor) in case you get that far.
http://techauto.te.funpic.org/vss.php
Old Mar 12, 2007 | 06:54 PM
Default Re: '91 speedo drops to zero while driving (BLKFLSH)
Thanks for the quick replies guys.
I checked the code and if I'm doing it right, I get 4 blinks from the LED light under the carpet on the passenger's side.
sacalait59
Apr 19, 2011 04:30 PM
bhome83
Apr 25, 2010 07:10 AM
micharev
Feb 4, 2009 05:50 PM
rommersk
Nov 2, 2007 04:17 AM
Monty
Sep 28, 2002 08:56 AM
