93 civic ex front swaybar size
Old Mar 12, 2007 | 04:57 PM
byronl's Avatar
Default 93 civic ex front swaybar size
what is the size for the front swaybar on a 93 civic ex coupe? is it 21mm or 22mm? I've been hearing mixed things and need to make sure.
I also bought some 21mm energy suspension bushings and tried to install them on but they seem to be too small and the brackets wouldn't line up to the holes. Is it supposed to b like that or do i get the 22mm?
Old Mar 12, 2007 | 05:19 PM
eg6ajk's Avatar
Default Re: 93 civic ex front swaybar size (byronl)
From what I recall 92-5 Si (hatch) had 21mm bar and the EX coupe/sedan got the 21mm bar up front as well! Its a possiblity that you a DC/DB (94-01) ls/GS Integra bar which is 22mm!
Modified by eg6ajk at 9:17 PM 3/12/2007
Old Mar 12, 2007 | 05:42 PM
JSPECSIR's Avatar
Default Re: 93 civic ex front swaybar size (eg6ajk)
here ya go, straight from honda. part #1
http://www.hondaautomotivepart...R+ARM
Old Mar 12, 2007 | 09:50 PM
byronl's Avatar
Default Re: 93 civic ex front swaybar size (JSPECSIR)
hmm, then i bought the right bushings, it just feels like the bushings are too small when i put them on the swaybar. Did anybody go through this? It's like the bushing doesn't fully surround the bar.
Old Mar 12, 2007 | 11:15 PM
BlueIntegraBoy's Avatar
When you tighten down the bushing, it will fully wrap around the bar.
Old Mar 12, 2007 | 11:49 PM
byronl's Avatar
Default Re: 93 civic ex front swaybar size (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">When you tighten down the bushing, it will fully wrap around the bar.</TD></TR></TABLE>
the brackets won't line up to the holes on the chassis, is that what i should b expecting?
Old Mar 12, 2007 | 11:56 PM
Are the holes too close together or too far apart?
Old Mar 13, 2007 | 09:12 AM
byronl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Are the holes too close together or too far apart?</TD></TR></TABLE>
too far apart.
oh yeah, i measured the diameter on the old bushing and i got 23mm.
luispizarro25
Aug 8, 2008 05:37 AM
fightback
Nov 30, 2006 10:35 AM
mingchi69
Jun 18, 2003 01:29 PM
willyboyK20
Mar 21, 2002 03:39 AM
