Oil leak around Distributor - Pictures added
Old Mar 12, 2007 | 03:23 PM
jchung's Avatar
Default Oil leak around Distributor - Pictures added
motor: d15b6, stock 89 crx hf
i think its leaking from the dizzy. i did some searches and looks like i might have to replace the dizzy o-ring which i already ordered. havent taken apart the dizzy yet. i also took some pictures of where the leak is from and also pics from under the car where its dripping some oil. just wanted some additional thoughts.
thanks in advance,
Old Mar 12, 2007 | 03:33 PM
Hamstr323's Avatar
Default Re: Oil leak around Distributor - Pictures added (jchung)
you answerd your own question
or here's an idea buy some degreaser clean the motor and see where tha damn leak is coming from!!!
Old Mar 12, 2007 | 04:23 PM
jchung's Avatar
Default Re: Oil leak around Distributor - Pictures added (Hamstr323)
haha, i can always use a 2nd opinion!
i opened the dizzy cap (after reading this: https://honda-tech.com/zerothread?id=1785447) after posting this and i saw no oil in the cap or the dizzy. i also popped open the valve cover to see of any leaks but didnt see any.
Old Mar 12, 2007 | 04:24 PM
jchung's Avatar
does that i mean i have to replace the internal seal inside distributor itself?
Old Mar 12, 2007 | 04:31 PM
Hamstr323's Avatar
no all you need to is relace the O ring that's it
Old Mar 12, 2007 | 05:11 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">no all you need to is relace the O ring that's it</TD></TR></TABLE>
Agreed, less than $1 and 5 mins to fix, no big deal
Old Mar 12, 2007 | 05:15 PM
PACT man's Avatar
Default Re: Oil leak around Distributor - Pictures added (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed, less than $1 and 5 mins to fix, no big deal</TD></TR></TABLE>
It cost me $1.56 at cost+10% from a dealership... But none the less, tis easy to change. The oil all over the bottom of your engine looks like you have bigger problems than just your dist. O-ring leaking. Might want to check your oil pan gasket as a start.
Old Mar 12, 2007 | 05:35 PM
jchung's Avatar
Default Re: Oil leak around Distributor - Pictures added (PACT man)
yeah it looks like the oil pan which i knew i already had to change. that along w/ the gasket is coming tomorrow.
i'll keep this thread updated as i replace the o-ring and the oil pan&gasket tomorrow or wed.
Old Mar 13, 2007 | 07:39 PM
elusive123's Avatar
Yea start with the valvecover and pan if the leak still persists then your rear main seal is most likely leaking also.
Old Mar 13, 2007 | 07:56 PM
hardEH2's Avatar
O-ring is probably the cause, I couldn't find the damn leak, looked in the cap, replaced the ring and havent had any problems yet
Old Mar 13, 2007 | 08:57 PM
jchung's Avatar
Default Re: Oil leak around Distributor - Pictures added (hardEH2)
Thanks guys. I got the o-ring today but had a real hard time loosening the top nut (out of the 3 that hold the distributor in place to the block), so I gave up.
Any ideas on how I can get that nut off?
Old Mar 14, 2007 | 03:16 AM
janz3n's Avatar
vise grips and a hammer.
Old Mar 14, 2007 | 11:20 AM
jchung's Avatar
Default Re: Oil leak around Distributor - Pictures added (janz3n)
grip the bolt with the vice then hammer it counter-clockwise?
Old Mar 14, 2007 | 11:36 AM
89efDUSTY's Avatar
use something for leverage...breaker bar of some sort. Vise grips and hammer is kind of hap hazard...if nothing else hit your ratchet, wrench, BB whatever you were using with a hammer...Vise grips can slip way easier and chew up the thread Common sense 101...and gl to you
Old Mar 14, 2007 | 11:51 AM
wiZCo's Avatar
Stouts 'n' Scotch
You can try using some PB Blaster then go at it again with a cheater bar (length of pipe) attached to your ratchet or a breaker bar to give it that extra torque.
Old Mar 14, 2007 | 08:42 PM
hardEH2's Avatar
Default Re: (wiZCo)
use the floor jack bar and put it on the ratchet and pull like a bitch.
Old Mar 15, 2007 | 04:15 AM
VegaS10's Avatar
Make sure to use a 6 point socket. A12 point may slip uder heavy torque, leading to a stipped bolt.
Old Mar 15, 2007 | 01:03 PM
elusive123's Avatar
Default Re: (VegaS10)
lol a f'in floorjack handle for a 8mm bolt, get your weight up. Use a fresh pair of vice grips if you have to go that far, it will grip perfect.
thedudefromjerz
Apr 21, 2009 10:19 AM
teambk8
Nov 2, 2008 01:47 AM
crxricer66
Jan 11, 2008 01:57 PM
morales232002
Sep 5, 2005 10:16 AM
vtecjdm
Jun 10, 2004 05:56 AM
