Spoon progressive shock + springs kit from EK fit on EG?
Old Mar 12, 2007 | 03:18 PM
Rikaro's Avatar
Default Spoon progressive shock + springs kit from EK fit on EG?
would the one made for the ek fit on the eg?
Modified by Rikaro at 1:23 PM 3/19/2007
Modified by Rikaro at 1:25 PM 3/19/2007
Old Mar 12, 2007 | 04:47 PM
eg6ajk's Avatar
Default Re: Spoon progressive shock + springs kit from EK fit on EG? (Rikaro)
Fronts will work, rear will depend on the fact if you have JDM style LCAs or USDM!
Old Mar 12, 2007 | 05:02 PM
Rikaro's Avatar
Default Re: Spoon progressive shock + springs kit from EK fit on EG? (eg6ajk)
so unless i buy a JDM, or aftermarket LCAs, otherwize it'll not work at all?
Old Mar 12, 2007 | 11:47 PM
Rikaro's Avatar
if i use omnipower lcas would they work?
Old Mar 14, 2007 | 02:10 PM
Rikaro's Avatar
anyone? please? thanks
Old Mar 19, 2007 | 12:21 PM
Rikaro's Avatar
i am getting different answers. Some guy says all i need is swap the LCAs, and another said the forks are too skinny for them. Please help me, i'm freakin pissed off
Old Mar 19, 2007 | 12:43 PM
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikaro &raquo;</TD></TR><TR><TD CLASS="quote">
Okay, just to set everything straight. Those are not for 92-95/96-00 civic. I believe those are for 01-up.
The front will work. However the rear will not. On the rear shock on the 96-00 civic. The fork is more narrower then the 92-95.
Basically you can not use the 96-00 onto the 92-95. But you can use the 92-95 on the 96-00 by using the correct size spacers.
Old Jun 1, 2010 | 10:01 AM
barman_'s Avatar
thanks for the info
all eg shocks are same?also in del sol's?
i have a vti del sol
thanks
PatrickFrantz
May 27, 2008 11:03 PM
Richie B
Suspension & Brakes
Jul 31, 2006 07:40 PM
TORQUE MONSTER
10
Jun 21, 2006 07:52 AM
rextec
Suspension & Brakes
Mar 7, 2005 07:40 AM
Bigjussin
15
May 22, 2004 10:40 AM
