mini me fuel pressure?
I am doing mini me d16a6 block with d16y8 head.and a( stock pm6 ecu crx si)
and i wanted to know the correct fuel pressure i should use on it with the adjustable fuel pressure regulator.thanks for the help in advance.this is a '90 crx si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF »</TD></TR><TR><TD CLASS="quote">whats the point in putting a vtec head on if your not going to use it? stock fuel pressure is fine.</TD></TR></TABLE>
Good point, the a6 head is a good part, if you don't want to use vtec might as well just install a y8 intake mani on your a6.
If you want a mini me then you should go obd1 and wire vtec.
mengy007
Sep 2, 2004 11:38 AM
