need help with car audio
alright so i got this car a while back and i noticed that the wires were cut for some reason and there was no radio in the car. so im planning on putting in just an old pioneer head because it's better than nothing. this is what it looks like :
anyone know what to do? crx's arent easy to find around here and most of the 88-91 civics at the junk yards dont have wire harnesses. maybe someone can show me how to hardwire it to a pioneer deck? im not sure on the model # but i can get back to you with that.thanks :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by htowncruiser »</TD></TR><TR><TD CLASS="quote">hey man the red wire is for power and the black is for ground. The other r for ur speakers. </TD></TR></TABLE>
Wrong.
The yellow wire is the constant power, the red is the remote on, the black is ground, and the striped ones are your speakers,
go off the wiring diagram on the back of your deck, it should be easy from there.
The easiest way to figure your speakers is to look in the speaker holes to find out what colors go to what side, left, right, etc...
good luck.
Wrong.
good luck.
Grab a double a battery and two wires, touch one wire to the top and one to the bottom. You will hear a speaker tapping when you touch the positive and negative for that speaker. Have some masking tape and label them for next time.
Hope that helps
Hope that helps
actually you guys are both wrong Honda's colours are different
12v constant = white/blue
acc/ign = yellow/red
ground = black
ill = red/black
left front + = blue/green
left front - = gray/black
right front + = brown/black
right front - = brown/black
left rear + = blue/yellow
left rear - = gray/white
right rear + = red/yellow
right rear - = brown white
ground = black
ill = red/black
pownzor14
Audio / Security / Video
May 19, 2009 06:09 PM
plzhitvtec
Sep 5, 2004 08:48 PM
