Civic brake lines
Ok I have a set of rear disc off a 2000gsr integra I am going to swap onto my 98 civic hatchback DX-I need to order stainless lines for the car and was wondering if I ordered 99/00 Civic Si lines if they will bolt up to the DX front calipers/GSR rear calipers combo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Yes, they will</TD></TR></TABLE>
Uh, are you sure 'bout that. The 99-00 Si has larger Nissin front calipers. They are not the same as the Akebono calipers that come on the front of his DX. I think the OP is gonna have to get 92-95 Si (non ABS) brake lines. The 92-95 Si has smaller Akebono front brakes and the same Nissin rear discs that come on the Integra...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">
Uh, are you sure 'bout that. The 99-00 Si has larger Nissin front calipers. They are not the same as the Akebono calipers that come on the front of his DX. I think the OP is gonna have to get 92-95 Si (non ABS) brake lines. The 92-95 Si has smaller Akebono front brakes and the same Nissin rear discs that come on the Integra...</TD></TR></TABLE>
I am sure that fitting on the caliper are the same though. The 92-95 Si non-ABS will also work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskoolaccord »</TD></TR><TR><TD CLASS="quote">well I am just gonna source a set of ex or si front spindles/brake assembly prob,that way I know the Si stainless lines fit for sure</TD></TR></TABLE>
If your going to be doing a complete front brake conversion, you will also need a larger master cylinder, so keep that in mind...
bensonwrx
11
Aug 9, 2003 04:23 PM
