Who has the highest HP all motor integra type r?
This is limited to the following:
It must be a b series motor running on stock wiring, ie no programmable ecu.
So who has the highest HP in the following:
1. Stock Block Stock Valvetrain- Meaning: Cams, ECU Bolt-ons
2. Stock Block Unlimited Head- Meaning: Cams, Valvetrain, ECU, Bolt-ons, Porting
3. B18 Block Unlimited Internals and Unlimited Head Work - Any thing that still has the stock B18 Block as a basis........
This is to solve a debate that a friend and I have had.
Just to put a little fuel on the fire.... a motor that was in my typer was a B18 block and had JUN components and ECU and made over 210hp @ wheels with large R compound wheels and ac! and PS!
Lip was dyno'd around 260whp and whatever torque all motor. I think this might be last years numbers though.
His engine isnt what most would consider "streetable."
Mike D
Mike D
wasnt some of his like nice 12 second times done with vtec broken?
Different dynos put out different power output. Also there are so many ways to get a dyno to read high numbers.
The dyno should be used as a tool to see an improvement before and after tuning.
Pretty sick
Mike D
There are cars hitting 12s with only 200hp
no ****? your point?
[Modified by Mr.Integra, 10:37 PM 5/22/2002]
Point is- NO BIG DEAL to hit 12s (From the earlier posts it sounded as if 260 hp to hit 12s was something special)
260hp should put you into the 10s.
that was with no vtec
yeah it was when he was having troubles with the car if i remember correctly. Then he dyno'd and realized he wasnt making **** for power because vtec wasnt engaging. But, as you mentioned, it was still good for a 12 second slip.
Pretty sick
Mike D
Pretty sick
Mike D
some dudde out here has a jdm front R and from what i herd he was breaking into the high 12's. then he over ported!
lol. now he runs 14's-15's
Lip's heavily modified GS-R can be seen in the banner ads up top for Z10 Engineering, the gold USDM front doing the burnout. Also on http://www.todaracing.com/drag.html on TODA Racing's web site in more details. I remember his dynograph of 242 wheel horsepower, with TWM individual throttle bodies and TODA C-spec cams. Look up Lip on the member list for links.
Most of you've seen the videos...two hundred and fifty, YES 250 "Whp", is Tony the Tigers GS-R!!!!
For a B18 he's gotta win hands down! I've been in it, it's a Freak Show!
TONY THE TIGER
ALL MOTOR
TONY THE TIGER
ALL MOTOR
Dyno Plot: Note: this is an older plot
http://www.geocities.com/leunghomepage/GSRdyno.html
Tony the Tiger
[Modified by 1250b18c5, 9:19 AM 5/23/2002]
Tony the Tiger
