Doing my own EG sidemarker install v.firsttimeiveusedadremel :EEK:
Old Mar 12, 2007 | 05:43 AM
BlackMagikSI's Avatar
Default Doing my own EG sidemarker install v.firsttimeiveusedadremel :EEK:
Soo, im going to be attempting to do my own sidemarker install in just a couple of hours. I ordered them off password with the wiring harness included. I bought a dremel (old one took a **** about a year and a half ago, and never had a reason to buy a new one) the other night with some reinforced cutting discs at Lowes for only $80. This will be the first time i'll ever cut something with a dremel that wasnt just a straight forward cut something in half lol. Im nervous, but confident that im not going to screw up, I've been practicing with some sidemarker templates on a sheet of metal for about 3 weeks now, cutting out the same pattern over and over, and now i'll attempt my fenders. Anyone have any final suggestions/comments/concerns/tips before I do this? Oh yeah, if everything comes out perfect, i'll be taking pics to make a final once and for all detailed write-up on sidemarkers on an EG.
$5 say I make a thread in 5 hours titled: WTB EG fenders.
Old Mar 12, 2007 | 05:52 AM
instrument's Avatar
my friend had his installed at a shop for 40.
good luck though.
Old Mar 12, 2007 | 06:11 AM
grayegcivic's Avatar
Default Re: Doing my own EG sidemarker install v.firsttimeiveusedadremel :EEK: (BlackMagikSI)
Dont forget to tape around the area that you will be cutting..it will help a lot in case your dremel will run away from your template...again good luck..its easier than you think it is!!! Just be patient!!!
http://www.tuner-junction.com/...46773
Old Mar 12, 2007 | 06:37 AM
Default Re: (instrument)
Seriously? Damn $40? I called around at first, and almost all the shops said they wouldnt do it, and the shops that said they would wanted to charge over $100. I'd rather do it myself anyway, better sense of pride I suppose.
Old Mar 12, 2007 | 06:48 AM
pdiggitydogg's Avatar
you will have a much easier time, cutting the fenders with metal nibblers, instead of a dremel.
Yes, it will take longer, but it will come out better too.
(they sell them at radio shack for cheap)
Oh, and you got ripped off on passwords wiring harness too....sorry, but its true
Old Mar 12, 2007 | 06:53 AM
Default Re: (pdiggitydogg)
Hey if its true, i'll accept that, nothing I can do about it now anyway, but thanks.
Old Mar 12, 2007 | 07:02 AM
verycleanhatch's Avatar
i used some kind of metal nibbler from radio shack for my sidemarkers it was easy and cheap.
Old Mar 12, 2007 | 07:12 AM
Default Re: Doing my own EG sidemarker install v.firsttimeiveusedadremel :EEK: (verycleanhatch)
I've been using the dremel as practice on some metal sheets for the last few weeks, at first I was like damn this is going to take me an hour to do. Now its like I can punch out a template in like 5 minutes. lol
Old Mar 12, 2007 | 12:28 PM
Default Re: (BlackMagikSI)
Arent those for a CRX?
Old Mar 12, 2007 | 12:49 PM
same concept of cutting!!! Just use whatever you comfortable with! Since majority is saying the metal nibbler is easy, might want to use those. But I used the dremmel on mine no problem!
http://members.***.net/ninety2...r.htm
Old Mar 12, 2007 | 01:22 PM
Default Re: (grayegcivic)
Did you print out and use that template? Will it work with the side markers from Password?
Old Mar 12, 2007 | 01:29 PM
No i didnt use that template! I used this one https://honda-tech.com/zerothread?id=1768387 but i had to convert the measurements!
Old Mar 14, 2007 | 07:02 PM
Well, update on my side marker install. I got them done today, I took a **** ton of pics, but much to my dismay, they came out too dark for some reason, im gonna try and have a friend lighten them up with photoshop. As for the install, it went well, I will say that the EG template I got off HT didnt work too well with the Stanley's. The template was too small, so I spent a good half hour slowely resizing and grinding the edges of the hole to make the side marker fit. In the end, it all went well, got them wired up which was to my surprise a breeze using wire taps from radioshack.
Only thing I have to figure out now is why in the world my passenger side blinker blinks at 56484648 times a second now. Its WAY faster than the driver's side blinker which is gay. I think the problem was that I cut thru the black wire, but then realized its not what I wanted to do, so I ended up redoing it, but I dont think I covered up the exposed portion of the wire with electrical tape. Any other ideas as to why its blinking so fast? I did a search, but most say its a short, or blown bulb.
In the end, they look awesome, and im super proud of myself for gathering the ***** to cut into my fender! lol
Old Mar 14, 2007 | 07:09 PM
ridin98civic's Avatar
do all your lights work? check your rear turn signal on the side that is blinking fast
Old Mar 14, 2007 | 07:11 PM
Default Re: (ridin98civic)
Yup, all my lights are working, I just went outside and tested them out, I mean unless im missing something lol.
Old Mar 14, 2007 | 07:18 PM
Civic98KH's Avatar
can i see pics on the progess, i would love to do this as well....
Old Mar 14, 2007 | 07:34 PM
Default Re: (Civic98KH)
I'll get the pics up tomorrow. As far as the ones I took actually doing the job, I'll have to wait to have my friend lighten them up. The job came out awesome dude, honestly, the hard part was getting the right measurments from the internet. The cutting which I used a dremel, was awesome, it cut thru the metal like butter.
Old Mar 14, 2007 | 07:59 PM
darkdemoneg's Avatar
Thanks
Old Mar 14, 2007 | 08:00 PM
Old Mar 19, 2007 | 08:19 PM
Civic98KH's Avatar
sle3py_se3z
Sep 19, 2010 11:00 PM
Manolo
Apr 26, 2007 08:50 PM
A.E Motoring
75
Jul 20, 2006 12:38 PM
