I just have all the luck lol
Old Mar 12, 2007 | 03:39 AM
JDM_EK4_Coupe's Avatar
(banned)
Default I just have all the luck lol
Well I was putting my valve cover back on and I broke a screw that holds the rubber seal. So I siliconed it as a temporary solution. Heres a pic
What can I do to fix this problem?
Old Mar 12, 2007 | 04:18 AM
(banned)
Default Re: I just have all the luck lol (JDM_EK4_Coupe)
Well I did a little bit of research and it appears that ive broken a stud if Im not mistaken. How should I go about it removing and replaceing it?
Old Mar 12, 2007 | 04:31 AM
ke98248's Avatar
It's a miracle when you started up your car that oil and **** didn't start leaking out that one side where the bolt was supposed to be. I'd have just left it how it was and wouldn't have messed with a "temp. solution". Anyways:
Scrap out all of that nasty **** you splattered into the hole. First take off the valve cover (if the bolt isn't stuck past the sealer), and clean it out very good. Then drill and tap the threads... Before you do that though, try and use needle-nose pliers to turn the screw if you can unscrew the bolt or pull it out. Be careful & GL!
Old Mar 12, 2007 | 05:25 AM
Projekt_2nr's Avatar
Default Re: I just have all the luck lol (ke98248)
wtf, lol. pull off the valve cover and remove the stud you should see that you should be able to use a crescent wrench and you can get it off, there is usualy aprefabbed spot on the head stud with a nut on it that you can loosen up. Then afterwards, go to a junkyard and get a new valve cover, and you can also pick up a stud off the same motor you get the valve cover off of.
Old Mar 12, 2007 | 06:56 AM
(banned)
Default Re: I just have all the luck lol (Projekt_2nr)
Thanks
Old Mar 12, 2007 | 07:11 AM
vlc92189's Avatar
yup, very easy fix, ive broke one or two before, take it off, torque it back down, remeber the 4 inside bolts though after the valve cover is off, is only 7 ft/lbs i believe..
Old Mar 12, 2007 | 07:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Thanks </TD></TR></TABLE>
no problem
Animefun
Oct 28, 2012 08:55 PM
CivicBlack
Feb 14, 2006 04:34 PM
00ekcoupe
37
Sep 5, 2005 06:15 PM
Geeq
Aug 3, 2005 02:46 AM
VR6T
Mar 6, 2003 04:22 AM
