Need Help choosing the right cams for my set up!!! Pls help!
Old Mar 11, 2007 | 11:31 PM
allmotorcrx415's Avatar
Default Need Help choosing the right cams for my set up!!! Pls help!
Ok guys! i need help choosing the right set of cams for my set up!
here's my set up:
b16a2 head p&p
jg valve springs & retainers
stock b16 cams
aebs intake manifold
portmatched t/b 68mm
rc 310 injectors
aem fpr & fuel rail
rage header
Bottom end:
stock gsr block for now!
im running a Hondata s200! daily driving car!
I was thinking of getting the s2s2 cams!
pls help me guys!
Old Mar 12, 2007 | 08:12 AM
nokturnal_munkeeboy's Avatar
Default Re: Need Help choosing the right cams for my set up!!! Pls help! (allmotorcrx415)
go with buddyclub spec 3 it will help you out. it better that type r or ctr cams
Old Mar 12, 2007 | 02:08 PM
00Red_SiR's Avatar
All Motor Mentor
Unless you've planed the head, decked the block, are using a thinner head gasket or flat faced valves, you're only running around 9.8:1 compression. At that level I'd stick with BC 3 cams, Skunk2 stage 1 cams, blox A's or ITR/CTR cams.
Old Mar 12, 2007 | 06:28 PM
Default Re: Need Help choosing the right cams for my set up!!! Pls help! (00Red_SiR)
Ok! thanks for the adviced guys! i appreciate it! i'll go with the stage 1... im using 2 layer head gasket, i have a high compression flat face supertech valves standard size...
Old Mar 12, 2007 | 09:32 PM
milano sir-g's Avatar
atleast throw some ITR pistons in it. Its not too hard(or costly these days for that matter) to drop the crank down and toss some pistons in. Also those injectors are overkill
Old Mar 12, 2007 | 11:48 PM
Default Re: (Milano SiR-G)
im just gonna try to run with the stock block first! then after that im gonna put a pistons for sure!
Old Mar 13, 2007 | 02:20 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano SiR-G &raquo;</TD></TR><TR><TD CLASS="quote"> Also those injectors are overkill</TD></TR></TABLE>
He's running a B18c, 310's are hardly considered to be overkill. Stock are 240's.
Old Mar 13, 2007 | 05:45 PM
Default Re: (00Red_SiR)
what do you guys prefer? the buddy club spec 3 or the skunk2 stage 1 cams?!
Old Mar 13, 2007 | 07:05 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (allmotorcrx415)
I had the S2S1's and loved them, they pulled really well in VTEC. BC3 cams seem to make better torque overall in many dyno graphs that I've seen. I'd go with whichever one you get the best deal on since they both work very well.
Old Mar 13, 2007 | 09:40 PM
Thanks for the info i appreciate it..
kennie555
Feb 22, 2013 12:45 PM
EKBOOSTDREAMS
12
Jan 1, 2007 06:06 PM
boostd ls
10
Jan 5, 2006 10:17 AM
hitvtecgetloud09
31
Mar 14, 2005 09:50 AM
gutted
Nov 17, 2003 05:17 PM
