shift lock release problem and break lights
Old Mar 11, 2007 | 11:10 PM
zachgk7's Avatar
Default shift lock release problem and break lights
i have an auto 95 coupe and for some reason when i press the break to move the shifter out of park it does not work the shifter is stuck the only way i can get it out is by sticking a key in the shift lock keyhole and putting my car in neutral then start it up HOWEVER when i do this my break light dont work are they connected somehow? this has been going off and on for about 4 months but now it wont go away and my break lights wont work even when the rare occurence trhat my shifter acts normally.
thanks
Old Mar 12, 2007 | 07:07 AM
JimBlake's Avatar
Default Re: shift lock release problem and break lights (zachgk7)
Yes, they are connected. There's a switch mounted near the pivot of the brake pedal. It triggers the brake lights, and it also tells the shift-lock system to release the shift lever.
Look for a broken switch, a bent bracket, a busted wire, or something wrong down at that switch.
redsidriver
Nov 28, 2011 06:08 AM
krisfnbs
Mar 16, 2011 01:29 PM
boblikesrock
Nov 29, 2006 06:55 PM
webthread
Sep 21, 2005 06:41 AM
yellowdcn
Feb 28, 2005 01:06 PM
