JDM D15B vtec compression issues..
Hey guys the compression on my swapped D15b vtec in all cylinders show about 165psi.. is there anyone else facing that problem and does anyone know how to solve it ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitroxx »</TD></TR><TR><TD CLASS="quote">Hey guys the compression on my swapped D15b vtec in all cylinders show about 165psi.. is there anyone else facing that problem and does anyone know how to solve it ?</TD></TR></TABLE>
What's wrong with that? <FONT COLOR="red">You can't judge compression with the psi readout from a particular tester!</FONT> <FONT COLOR="red">You can't judge compression with the psi readout from a particular tester!</FONT> <FONT COLOR="red">You can't judge compression with the psi readout from a particular tester!</FONT> <FONT COLOR="red">You can't judge compression with the psi readout from a particular tester!</FONT> <FONT COLOR="red">You can't judge compression with the psi readout from a particular tester!</FONT> <FONT COLOR="red">You can't judge compression with the psi readout from a particular tester!</FONT> Compression testers give you a range of variance, not a solid number that you can plug in and factor compression from.
Thats fine. You can go drive now.
