axle removal
is there a special tool to remove the axle from the spindals? i just cant seem to break the nut off. Yes i knocked the peen out but is there something im missing cause i had a breaker bar with 3 200+ pound guys pushing on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch »</TD></TR><TR><TD CLASS="quote">did u use pb blaster at all</TD></TR></TABLE>
yeah i soaked the ends in PB let them sit for about 10 min and still couldnt get them off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 »</TD></TR><TR><TD CLASS="quote">man power and a very long breaker bar... or power tools</TD></TR></TABLE>
we had a big pipe on a 3ft 1/2 in drive breaker bar and the nuts wouldnt budge
use more man power
u have have to jerk it acouple times kinda like the air gun does...then push down on the bar. use wd-40 good luck with it...ive had this get stuck on me b4 too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdavie »</TD></TR><TR><TD CLASS="quote">I've always just jumped on the end of a breaker bar while a friend stands on the brakes. It's worked every time.
More PB blaster plus some heat, maybe?</TD></TR></TABLE>
i dont know if they are corroded on or they are just that damn tight after what about 15 years of being on their
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">impact came right off for me</TD></TR></TABLE>
same here
same here
You dont know anyone with air tools? Most 1/2 inch impact guns should take that right off. Sometimes a breakerbar doesnt always work.... i've broken 2 of them in the past trying to get axle nuts off lol. PB blaster does help also, as well as using a torch.
I had broken 2 breaker bars trying to get mine off. I used a pipe about 6 ft long and just bounced on it while my buddy was holding the brakes. Make sure you are turning the right way ;-P. use some heat and get it red hot then try to get it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal »</TD></TR><TR><TD CLASS="quote">You dont know anyone with air tools? Most 1/2 inch impact guns should take that right off. Sometimes a breakerbar doesnt always work.... i've broken 2 of them in the past trying to get axle nuts off lol. PB blaster does help also, as well as using a torch. </TD></TR></TABLE>
yeah i do we just used his **** and the nut still wouldnt move.
so what we did was just split the nut on the drivers side and were gonna do the passenger side tomorrow when the sun comes up
You don't need a torch...
You don't need PB Blaster or WD 40 or whatever.
You don't need a 6-foot pole
This is what you need to do:
1.) Get out your air-compressor and air gun.
2.) get out your big 6-point impact socket for removing the axle nut
3.) Pump your air compressor up as high as it will go.
4.) DO NOT HOLD the trigger down on the gun.. instead quick short repetive blasts on the gun will loosen the nut.
I have found that >140 psi works best.
BTW it's the same process for the crank pulley bolt removal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave »</TD></TR><TR><TD CLASS="quote">You don't need a torch...
BTW it's the same process for the crank pulley bolt removal</TD></TR></TABLE>
the crank pulley bolt is 17mm the axle nut bolt is 32mm. Thats just about double
im just gonna split the other one
