brake booster ?
Old Mar 11, 2007 | 08:34 PM
HFpower's Avatar
Default brake booster ?
can u use any brake booster from a DA
does it matter if its ABS or not
Old Mar 11, 2007 | 08:49 PM
92civicfreak's Avatar
the ABS brake booster has 1 larger fitting than the non-abs... i will either have to use the non-abs or u will need a flaring tool, so when u cut off the smaller fitting on ur car & install the bigger one u can flare it properly
Old Mar 11, 2007 | 08:56 PM
HFpower's Avatar
Default Re: (92civicfreak)
i think your talking about the master cylinder '
yea i know M/C are diffrent but r the brake booster diffrent
Old Mar 11, 2007 | 09:04 PM
4DRmafia's Avatar
i used a non abs one
Old Mar 11, 2007 | 09:28 PM
HFpower's Avatar
Default Re: (SkipMic2006)
yea but r the booster the same or diffrent
Old Mar 11, 2007 | 10:04 PM
Targa250R's Avatar
be professional
Default Re: (HFpower)
What exactly are you trying to do?
Old Mar 12, 2007 | 05:18 AM
CRX Toad's Avatar
Default Re: brake booster ? (HFpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">What exactly are you trying to do?</TD></TR></TABLE>
If you are wanting to swap in Integra MC/Booster you need to keep them together. Such as only non-abs MC will work with non-abs booster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">the ABS brake booster has 1 larger fitting than the non-abs... i will either have to use the non-abs or u will need a flaring tool, so when u cut off the smaller fitting on ur car & install the bigger one u can flare it properly</TD></TR></TABLE>
Also correct
Calvinator
Northern California (Sales)
Oct 21, 2008 05:54 PM
spoonhatchblack
Jan 5, 2007 09:39 PM
Beau Gotti
Oct 16, 2006 11:36 PM
mxpx035
Jan 5, 2006 02:16 AM
1EK1EG
Oct 15, 2004 04:15 PM
